Rod Knock? Motor going out? My luck BLOWS!! HELP!!
yes they can repair only the rods and bearings i did this with a bmw m3 the upper part of the engine i didnt even touch it and the car was fine after that but i sold it better!
Originally Posted by smokedmustang
It idles fine, just when you put your foot on the gas, you hear it!!
go under the car and slightly accelerate it well someone else and listyen carefully at the oil pan
get a long socket extension and use it like a stethoscope. With the engine running place one end of the extension on the block down low and the other end in your ear. Move it all over the engine and heads. This can help isolate where the noise is coming from. Dont drive it or run it too long. Since you say the oil was low when the noise appeared, I would say its a spun bearing. Low oil pressure will do this quicky. A rod knock will be very audible and should be present at all rpms, even idle. A spun bearing will do this as well but at first it will not be as loud but as time progresses and the damage gets worse the noise will get louder. Of course, if it is a spun bearing it is chewing up your crank and the rod, metal is going thru all the oil passages and your turbo, all over your cams while they are rotating, your oil pump.....you get the picture.
Sorry to hear your misfortune
I just had a few mechanics over, and they said the noise is DEFINETLY the piston slapping around in there, and he told me to "save" the piston when its replaced, because it looks wild.
I have 500 miles TOPS on it, since all the Fluid change. 2 weeks ago. NEVER smelled smoke, burning oil, saw any smoke. THERE IS NO SPOT on my garage of oil. Where did I lose 5 quarts of oil??? UNLESS IT WASN'T PUT BACK IN!!!!! could I have left the dealership with NO OIL IN THE CAR?? They say yes (the ones who looked at it 10 minutes ago!)
Originally Posted by WHTEVO
You WILL have to get your crank reground (depending on the extent of the damage, if it needs alot taken off, it is not recommended), repolish the journals and get a set of bearings that match what they need to be at now. If you replace the bearings and recondition the rods only, all your hard work will be for nothing. It will knock again. Good luck.
the most probable cause was that they didnt put back the oil dealerships suck
sorry again to hear this
