Rod Knock? Motor going out? My luck BLOWS!! HELP!!
Old May 4, 2006 | 01:50 PM
  #61
ROC's Avatar
ROC
By the way , I will take a cheese burger w/ketchup and mustard, fries, and a water
Old May 4, 2006 | 02:07 PM
  #62
smokedmustang's Avatar
Let me get my paper hat and my hair-net, and whoop one up for you!
Old May 4, 2006 | 02:09 PM
  #63
Originally Posted by gsujeff55
if there was oil on the dipstick at all, the dealership put oil in there.
quart low won't blow shiat up, but i wonder what caused your problem? were you driving around fat chicks again? you know, the extra load on your motor when you got a car full of fat chicks will cause bad things to happen at peak tq.
ive warned you about this previously kevin!
sorry to hear about your misfortunes. stroke it.
Jeff
I give rides for the morbidly obese for $5.00 per mile!
Old May 4, 2006 | 02:13 PM
  #64
Here is an interesting question, at first, it sounded like a radiator fan scraping on something. COULD my turbo hit the crapper, and sucked out all my oil, and the subsequent ride home caused my bearing to go out? it was a "TICKING" first, then the thud. maybe the impeller wheel went out first???? Is this possible?
Old May 4, 2006 | 02:30 PM
  #65
gsujeff55's Avatar
would the car make boost?
Old May 4, 2006 | 02:59 PM
  #66
I wasn't looking, it just felt funny, like it was going to stall, probably not much boost. here is a photo of the TME turbo, does it look fine? I guess so, not much play in the shaft.
Old May 4, 2006 | 03:07 PM
  #67
gsujeff55's Avatar
looks like there is a large amount of oil where the turbo bolts to the licp to me
Old May 4, 2006 | 03:14 PM
  #68
RaNGVR-4's Avatar
i dont see any problem. you wanna see a bad turbo, its going to look waaaayyy different than that..
Old May 4, 2006 | 03:20 PM
  #69
I am using this now, so the "large" ladys can shave down their frozen snickers bars in the impeller blades!!
Old May 4, 2006 | 03:30 PM
  #70
bigyellowevo's Avatar
That turbo is fine. If the turbo was bad, you wouldn't have the symptoms you mentioned anyway. Good luck with it...
Old May 4, 2006 | 03:53 PM
  #71
DrBump471's Avatar
geez Smokey. This stuff just doesn't ever stop for you does it? Good luck with it and let me know if I can help in any way.
With this car and the paths it has taken you down . . . . . don't rebuild, rebuy. I smell IX
Old May 4, 2006 | 04:21 PM
  #72
gsujeff55's Avatar
LOL
Old May 4, 2006 | 05:26 PM
  #73
althemean's Avatar
something went thru the turbo, there appears to be damage to the outer edges of the blades. That does appear to be an excessive amount of oil on and in the compressor housing.
Old May 4, 2006 | 05:52 PM
  #74
I re-started the car, and you cant hear it the 1st 3-4 minutes at idle,the idle sounds NORMAL. It's just when you "feather" the gas to 1,500K rpm, then you hear it!( I didn't want to idle it past the 3-4 minutes) noticable, but not LOUD. the mechanic dudes who came over said it is coming from cylinder #2. Just updating you on my findings!
Old May 4, 2006 | 07:37 PM
  #75
RaNGVR-4's Avatar
hmmm. pull the spark plug and see if it has any sign's of damage.
