Rod Knock? Motor going out? My luck BLOWS!! HELP!!
Am I missing something here....... if the dealer justed changed the oil shouldn't they repair the engine. Smoked you said it was few quarts low. Have them flip the bill, my dealer would, if we just changed it.
Did the turbo blow..... Did you check your licp for oil? Maybe that is were the oil went. I see it alot on the TDI VW's
no, the lower intercooler pipe is on the cold side of the turbo, but the hotside of the intercooler, if that makes sense.
the licp is the pipe going from the turbo to the intercooler. the upper pipe is the pipe going from the intercooler to the throttle body.
the licp bolts to the turbo right where it looks oily in your first pic, where it turns from silver to black.
yes, lots of blow by.....OR you blew a seal in your turbo. but it would also be POURING out of the exhaust if it was a blown seal
Thanks for the tip!!!
Drained the oil, its NOT GRITTY, and I cant see any pieces of anything in there. I had a second opinion and no grit, no pieces. I put the oil in a white container of plastic, THEN drained the oil thru a pillow case to see if it left anything behind. NO!! Someone mentioned possibly the balance shaft belt broke. I did have the oilpump balance shaft "out" 180 degrees for 4K miles. could this have any effect? Do the two sound the same? Spun rod bearing, and a broken belt to the balance shaft??
check the timing belt for correct tension. do a compression test. see if the noise is there with the clutch in and out, if its there for only one its probably clutch related.
Its official, rod bearing has spun!!! Here are some pictures, sorry they are kind of blurry. Again, I saw NO indication when draining the oil, as far as copper chunks, and that gave me a FALSE sence of security that the problem "isn't that bad". well, it is!!
Time for an AMS stroker looks like to me!!!
