Broken balance shaft belt or spun bearing.
Originally Posted by smokedmustang
I saw NO copper shavings/chunks when i drained the oil, but here is the photos I took 1/2 hour ago, after the pan was removed!!
Sorry to see that. I wonder what caused that to happen...low oil level? You might have caught it early enough. Best of luck
Originally Posted by anjapower
Did you pull the oil pan yourself
Originally Posted by FatheroftheEVO
yea that blows man. i am surprised that you didnt see a metallic tinge to the oil, you should have with a spun bearing. is the bearing fused to the crank?
dont get me started . In my usual fashion, I pulled out 1/2 of the oilpan bolts in my garage, and couldn't get the Downpipe off, so I had it towed to the dealership. I re-thought when and how, and here is my conclusion. the oil was barely on the dipstick, and we went around some sharp turns (like Lombard street) in San Fran, that caused what little oil was there to slosh arould and cause the oil-starvation and the rod bearing issue. thanks for the wishing me luck, I will need it.
Whoever changed your oil last forgot to refill the car. You mentioned that the car only had one quart of oil when you checked it after you heard the knock. I doubt that your car lost three quarts of oil since the oil change.
I would go to the place that changed the oil and tell them what happened and the damage that their geligence has caused.
Originally Posted by nj1266
Yep that would cause a spun bearing. We had an SR20DET at one of our track days that was running low on oil on a very twisty track. He comes in the pits with rod knock. He got a spun bearing like you have.
cmspaz
Dec 10, 2011 01:48 AM
4doorbullit
Mar 18, 2010 06:37 PM
