I think my Engine is done.....
Old May 8, 2006 | 06:38 AM
value's Avatar
PHP Code:
my vote is UICP is rubbing on the radiator fan.
Wow that's a good one. Have to remember that
Old May 8, 2006 | 06:54 AM
anjapower's Avatar
Originally Posted by value
PHP Code:
Are you being facetious? I was serious. His symptoms sound exactly like the upper hose rubbing on the radiator fan.
Old May 8, 2006 | 12:43 PM
SilverIX's Avatar
Let us know what you find? I'm very curious now.
Old May 8, 2006 | 12:54 PM
bigjhoney's Avatar
Its your aps bov tapping the fan casing. I have the same valve, had the same noise over a year ago. The way it sits, makes it sit wayyy to close to the fan , pop the hood and take a look( even try tapping the aps valve againt the fan casing yourself to see if it remakes the same noise... try to push/stretch the hoses as far away as possible. Havent heard it since.
Old May 8, 2006 | 01:40 PM
Ph3n1x's Avatar
So far no noise still after one day.....
Old May 8, 2006 | 01:46 PM
TTP Engineering's Avatar
This in fact is common and in many cases wears down a HOLE in the upper rubber pipe.
Old May 8, 2006 | 05:28 PM
Ph3n1x's Avatar
I did notice at that area the hose is sorta shredded. I think ill replace it with Samco hoses.
Secondly there is another rattling that could have been what i heard last nihgt commingfrom the passenger side bottom of the car.
Its by far not as loud but sorta similar.
Old May 8, 2006 | 05:37 PM
dubbleugly01's Avatar
when my car gets hot from a long drive (especially with a/c on in the summer), the tranny rattle is always elevated. You should hear a supra with a lightweight flywheel. You'd swear the car is broke, but it's normal.
Old Apr 21, 2013 | 11:19 AM
Ricoswave's Avatar
+3 on the rattling from the fan hitting the uicp. Mine has done it before.
Old Apr 21, 2013 | 11:22 AM
xXANCHORMONXx's Avatar
Holy thread revival!
I think it's been figured out, it is from 06
Old Apr 21, 2013 | 11:43 AM
Strider1048's Avatar
Did someone say Chris Redfield?
Hileyrolen
May 10, 2016 01:01 AM
EugeneT5
31
Apr 23, 2010 08:46 AM
gregrego
58
Sep 14, 2009 12:16 AM
Stew
335
Mar 9, 2006 05:10 PM
sir lurks alot
Nov 6, 2003 06:26 AM
