6 speed in regular Evo? how much $
Old May 8, 2006 | 07:54 AM
Scot's Avatar
The 5 speed has that HUGE (I MEAN HUGE) gap between 4th and 5th gear.... thought I could cure that with a MR 6 speed.
anyone swap yet? if so, about how much was the tranny and the labor to do the swap? Any problems with it?
thanks
Old May 8, 2006 | 08:30 AM
djskyy's Avatar
you're better off selling your current car and buying a MR version....
Old May 8, 2006 | 08:32 AM
Kordwood's Avatar
Wouldn't the ECU also need to be modifed or replaced for something like this?
Old May 8, 2006 | 09:17 AM
lunguv's Avatar
I would guess no, since its a mechanical replacement, its a manual transmission, not an automatic.
Old May 8, 2006 | 09:26 AM
EVOla_VIRUS's Avatar
geez...the gap aint that huge
Old May 8, 2006 | 09:42 AM
Agent-Smith's Avatar
it will cost around $4600 + whatever you need to fit the shifter in the car.
Old May 8, 2006 | 11:09 AM
bolsen's Avatar
Don't waste your money.
If your primary concern is the gap between the gates, I'm guessing you are concerned with time taken to shift. If this is true, keep in mind you'll be shifting more often with a 6spd ;-)
Old May 8, 2006 | 11:26 AM
Scot's Avatar
i was thinking a used MR tranny for about $1200 and maybe $400 to get it installed???
4th gear redlines at about 110mph and 5th gear redlines at about 165-170mph.... that is a HUGE gap to me!
It is almost like shifting from 4th to 6th in a normal car.....
Old May 8, 2006 | 11:30 AM
Fireball's Avatar
Different tranny mounting, different gear shifter, different linkages, different ECU programming.
Last time someone did a serious evaluation into this, the cost totalled about 12k-15k.
IF you want an MR 6 speed, buy an MR.
Old May 8, 2006 | 11:33 AM
elhalisf's Avatar
you will need the transmission, tranny mount, shifter cables, shifter base and shifter. a 6 speed tranny with base and mount ended for $1300.
Old May 9, 2006 | 12:35 PM
Scot's Avatar
wow...different tranny mounting.....cables, etc.....
Just being cheap.... figured a 03 with 25k miles for under $20k.... i thought for $2k to get into a 6 speed, then sell my 5 speed tranny for $600... $1400 net.... sweeetttttttt.....
maybe not....
Old May 9, 2006 | 02:03 PM
Rich@Orbital's Avatar
www.teamrip.com
I don't know where you guys are coming up with the $12-15k, that sounds quite a bit on the "steep" side.
Old May 9, 2006 | 02:17 PM
James's Avatar
my evo when i had it, 4 gear read line at around 120 not 110
Old May 9, 2006 | 02:22 PM
bluetorch's Avatar
where you finding 03 evos for under $20,000 with only 25,000? cause i havent seen any in mn
Evodriver1
15
Apr 8, 2020 04:21 PM
tauro91
Apr 26, 2017 06:48 AM
Tanman1986
23
Jul 25, 2010 12:17 PM
mr 2.3 evo
Jan 12, 2010 10:59 PM
RevMoto
13
Apr 4, 2009 08:28 PM
