LOOOK!!! transmission fluid?
I have not used it in my tranny as of yet but I will, it's called " NEO synthetic RHD" and it was hands down the best tranny juice for the DSM's and I have tried them ALL!! It is pretty notchy until it warms up, but when it's warmed up, NOTHING compares..If it's good enough for F1 and NASCAR it should be good enough for me..Can be purchased through www.bakerprecision.com Only downfall is the price, at 18.95 a qt. it is NOT cheap, but it has friction modifiers already mixed in which would normally cost you another 10 or 15 bux. BTW my experiences with all 3 of the BG synchro shift products were not giving me any positive results over stock or penzoil.. The next best thing was stock fluid with a mix of GM friction modifier, that worked well, but not as good as the NEO..
Originally Posted by TeStUdO
Penzoil worked great for me, it just needs to be replaced every 5k miles or so.
I personally liked the OEM fluid the best, had it in for 12k and it was butter smooth. The Pennzoil syncromesh I've been swapping out every 4k...it is cheap and readily available, but doesn't last too long.
Ghilversumtuner
Lancer Tranny/Drivetrain Tech
23
Apr 11, 2019 09:28 PM
