Titanium turbo manifold?
Originally Posted by hondafan
why does it work for streetbike exhausts then? i'm confused. a japanese superbike such as a GSX-R 1000 or R1 have pretty hot exhaust gases and run extremely high compression and titanium exhausts maintain a cooler temp than stainless and aluminum. why is titanium good enough for a bike but not a car?
Also, though I can't speak for street bikes, the EGT in naturally aspirated applications is usually quite a bit lower than turbocharged applications. But things get hairy when the N/A engine is revving to 18,000 RPM and the mixture is still burning as it exits the head.
Originally Posted by trinydex
see what i want someone to tell me is how is the coloring on that thing. doe sit show weakness? i know blue is acceptable and gold is great on SS but... ti????? clueless.
Originally Posted by Azom
The colour of welds can be used as an indicator of shielding effectiveness and, indirectly, weld quality. Thus, any indication of the quality level of a single pass titanium weld is readily apparent to the welder and any inspector. Weld colours reflect the degree to which the weld was exposed to oxygen (air) at elevated temperature. A bright silvery metallic lustre generally can be taken as an indication of a good weld, provided the weld joint was clean and good techniques were followed.
AFAIK, the goldish color is just a natural and thin coating of titanium nitride which forms any time titanium gets hot enough. But I'm not completely sure.
You would think Ti turbo manifold would work for a street car at least.. i mean i can understand it not working for race cars because they are full throttle the whole time.. but a street car how long can you hold down the throttle befor hitting a light or getting pulled over lol ....
soo the only other option is inconel which seems to not be to much better then stainless it seems.. Does any aftermarket company make inconel turbo manifold for the evo or is that a custom only.. thanks everyone.
it's cheaper to cast inconnel than to bend and weld it i thinks... and the tooling shouldn't be drastically different from casting anything else.
supposedly there are many cast inconnel manifolds. but i haven't personally come across any.
ElectrIX Blue
Nov 28, 2010 09:07 AM
NocturnalEVO
Nov 3, 2009 10:14 PM
But I wouldnt buy it hehe
