Not very impressed with Buschur's mini battery kit.
Old May 14, 2006 | 05:52 AM
Richard Sierra's Avatar
The stock airbox does not fit very well. I was only able to get one of the two bolts in. The front bolt is a good 1/4" off. This is with the battery shoved all the way back and grinding about an 1/8" off the aluminum tray.
It also has a lot of sharp edges that look like they could chafe the wiring harness that rubs the tray. I expected a lot more from Buschur for $225.00.
Old May 14, 2006 | 05:56 AM
smokedmustang's Avatar
I opted for the Miata battery for 50.00. No problems there!!! I think you might have it in wrong, because I NEVER heard anything bad about their mini battery kit!! I just didn't want to pay that much for any MINI battery. the miata battery did the job for me!!.
Old May 14, 2006 | 06:34 AM
Jasil's Avatar
I'm not saying it's perfect it's not hard at all to install and what wires will get "chaffed" there aren't any touching the base unless you did something wrong?
Old May 14, 2006 | 08:34 AM
EvoDan2004's Avatar
Originally Posted by trueno429
stop whining
relax there. for that kind of money it should not be a problem. that is y i went with nisei's mini batt kit.
Old May 14, 2006 | 08:52 AM
Zeus's Avatar
Shoot us a a few pics Richard... have you called Buschur yet?
If this turns into a Vendor bash... you know where this thread will go people.
Old May 14, 2006 | 08:55 AM
feldguy's Avatar
Mine worked fine. It wasnt 100 per-cent, but I would say 98% perfect. I noticed a few times I had it in incorrectly. Otherwise that little battery cranks and HARD
Old May 14, 2006 | 09:00 AM
fromWRXtoEVO's Avatar
stop whining
Let the guy give some feedback bro. Ultimately it will benefit everyone, is called constructive criticism, knowing how good Buschur shop is they will listen and try to improve their products. Is all part of the game.
Carlos
Old May 14, 2006 | 09:08 AM
vwjeff's Avatar
Maybe you should call Dave and not post something like this.
I don't think you are to use the stock air box with that battary kit.
Old May 14, 2006 | 09:22 AM
WillEatUrSTi's Avatar
I think vwjeff is right I thought it said on Buschur's website that the mini battery does not fit with the stock air box but perhaps with enough voices he would look into making one that does.
Old May 14, 2006 | 09:24 AM
midwestmonster's Avatar
Do any of you guys have problems with your battery not holding a charge if you don't drive your car for week or so? Mine gets very low and almost doesn't want to start.
Old May 14, 2006 | 09:29 AM
Yes, I had that problem.
Carlos
Old May 14, 2006 | 10:37 AM
CarFanatic's Avatar
ITs not ment to be used with the stock air box. MY battery dies too if I dont drive the car for a week.
Old May 14, 2006 | 10:38 AM
Carlos
How did you fix it? Just keep charging it or disconnect it when you're not driving the car?
Old May 14, 2006 | 10:41 AM
Just take off the negative terminal when not using it for a period of time I guess, or get a "trickle charger" I havent had that problem.
Old May 14, 2006 | 11:02 AM
kf6ytc's Avatar
mini batterys are worthless........ they don't hold a charge and the lifetime is less than a year......
