True Mitsubishi TD06H-20g????
Originally Posted by kjewer1
How was this statement validated? I'm interested in the numbers, wether it be dyno, track, or even just mass airflow.
I would stay far away from quoting anything to do with CFM, or any other volume measurement, and stick to mass flow measurements. And at 15 psi with those two turbos and a front mount intercooler, efficiency is irrelevant.
The 50 trim will make a little more power only because of the larger hotside, but at 15 psi there is not a lot of power to be gained here. Whatever power is gained is offset by the extra lag at the track. For people just looking for a strong pull on the street, you will probably enjoy the slight increase in power. But on the track, the extra power won't offset the disadvantages. Don't take my point the wrong way though, I'm all about larger turbos, and usually turbos that were bigger than I really needed. My main concern in this thread was the reasons people were giving for the extra power, and the strange comparisons being made
Slowboy racing did a recent turbo testing to about 25 different turbos on the same engine/same dyno. 8.3/1 compression 2.0. At 15 psi the evo16g did 344hp/290tq. The 50 trim did 290hp/280tq. The 16g was spiking trying to hold 15. At 20psi the 16g did 344/344. At 21psi the 50trim did 364/360.
Tdo6h/20g. bastard. small16g housing milled to exept 20g wheel. 15psi did 352/298, 20psi did 387/350. 30psi 422/459. The 50trim did 425/423 at 27psi.
erggy
Mar 5, 2006 07:32 AM
