Boost problem....need help
Old Sep 20, 2006 | 07:01 AM
KazzEvo8's Avatar
Which MBC? Disassemble, clean, remount... this is in response to the original poster. I don't know what you mean by "surging" without more description.
Old Sep 20, 2006 | 01:51 PM
WEVO's Avatar
I have the greddy profec B II.
It's making this chi chi chi noise when going wot. It's really driving me nuts.
Old Sep 20, 2006 | 01:58 PM
Warrtalon's Avatar
YOu might have an installation issue, WEVO. Put on the stock BOV and test. Did you already do that? You said you followed my steps, but you didn't specify. Are you saying this problem occurs with your stock BOV, too? If so, then remove the EBC and go back to the stock boost system (requires the stock OEM boost lines) to see if the EBC is causing problems.
Old Sep 20, 2006 | 07:09 PM
WEVO's Avatar
Yes I did, I'm using the JDM stock bov now. I'll remove the EBC next to locate the problem. I'm jsut wondering if my turbo is damaged or something? Is there that possibility?
Old Sep 20, 2006 | 07:14 PM
caswanso's Avatar
Originally Posted by WEVO
Bump for the thread. I'm experiencing the same problem.
When my car hits full boosts it starts to studder and I can hear this chi chi chi sound (sounds like my GFB bov is blowing off early), different from the regular fluttering sound.
Do I need new plugs or something? Everything was working fine until recently!
I have around 11000miles with HKS RS intake, TBE, 255 fuel pump, boost control, GFB bov and AMS custom flash.
Sounds like you need to oil your BOV or you may need to back the tension off a little.
Old Sep 20, 2006 | 07:17 PM
WTF_LOL's Avatar
define the studder more.
I had a similar problem. Took off MBC and found the smallest metal sliver where the ball seats. Cleaned, remounted, problem gone
Old Sep 20, 2006 | 07:21 PM
caswanso's Avatar
I wouldnt think that you would have any turbo damage with the amount of miles tha tyou have. You may have to work on the gate pressure and sensitivity settings on your boost controller. Warrtlon, what is the possibilty that these cars may be pulling timing?
Old Sep 21, 2006 | 08:03 AM
KazzEvo8's Avatar
Exactly - cleaning my MBC rectified much but it came right back. The ball's beat to hell. *Shrugs* I'll take care of it, but I assume others have the exact same issue.
Old Sep 21, 2006 | 12:05 PM
Warrtalon's Avatar
They may be pulling timing, but these symptoms are not an indication of timing being pulled.
lightingyellow8
Aug 8, 2005 10:28 PM
BaLListic_EVO
15
Jun 17, 2005 01:19 PM
ERGO EVO
16
Jan 31, 2005 11:54 AM
pkjing
Oct 28, 2004 06:56 AM
93civEJ1
30
Jul 3, 2004 12:23 AM
