Intercooler spray
Old Apr 18, 2003 | 03:33 PM
JasonS's Avatar
Originally posted by Secret Chimp
When I was at the track this weekend, I set the sprayers to auto. With the outside air temps being only about 55 degrees, I still only used about half the bottle over the 3 days of track driving.
Instead of putting alcohol into the bottle, why not throw a bunch of ice cubes into the tank? I bet very cold water would work just as well as a water/alcohol mix....and it wouldn't seem nearly as dangerous a proposition.
SC~
I'd thought about the ice cube thing as well, I may try it at VIR next week for their track days.
Also, GET_SUM 30, iirc, the intercooler spray tank is listed at 1 gallon, which judging by the size of the two spray nozzles should last awhile, I would think...
Old May 21, 2003 | 06:16 PM
Diesel's Avatar
where are the nozzles located, and does it spray the front surface of the IC...?
Old May 22, 2003 | 11:45 AM
JasonS's Avatar
look into the grille in front of the intercooler, and you'll see two spray nozzles about 8 inches apart at the bottom of the grill. They spray upwards in front of the I/C.
Old May 22, 2003 | 12:14 PM
EVOeight's Avatar
I wish there was an indicator light that showed when the pump was actually spraying, not just what mode it is in. I guess that would be easy enough to do though. I just wish I could see how the thing cycles when in automatic mode...
Old May 22, 2003 | 12:53 PM
Heggley's Avatar
Hmm, does the rocker switch stay in the auto mode? mine seems to click forward, then return to the middle. The manual spray works just fine.
Old May 30, 2003 | 12:23 PM
spyderturbo's Avatar
Hey guys....
I think I have a problem with the resovoir for my intercooler sprayer. I went to fill it today and it started to pour out of the bottom of my front bumper.
It looks like the clear hose which is located at about the half way point on the resovoir container on the left is draining the water out to somewhere? Once it drains past the level of that clear hose...it stops dripping.
Is this normal? Is the container only supposed to be about 1/2 full visually?
Or maybe that clear hose got disconnected from something?
Thanks!
Old May 30, 2003 | 12:30 PM
EVOeight's Avatar
I believe that the clear hose is the overflow. I have no idea why they would put it so low on the tank though. It seems like it could hold another pint or so if that wasn't there...
Old May 30, 2003 | 12:35 PM
Me neither...makes me wonder also. It looks like theres 2 hoses one black and the clear one going into the tank.
I'm just curious if the clear one is in fact just the overflow.
If it is....well, at least I'll have have the peace of mind knowing its normal.
Old May 30, 2003 | 12:37 PM
SilverEvo8owner's Avatar
Originally posted by spyderturbo
Hey guys....
Thanks!
Yeah! The same thing happened to me. The first time i saw it it scared the **** outta me
But it is normal
Old May 30, 2003 | 12:41 PM
hehe....cool!
Thanks for the feedback.
Now back to my regularely scheduled programming
TxFAkuma
Jun 23, 2014 07:38 PM
Jonathon Raby
Lancer Troubleshooting
Oct 29, 2012 07:12 PM
Landshark
Jun 21, 2011 09:21 AM
DJ Jazzy Death
12
Jan 19, 2011 07:53 AM
JdmEvo's
Jan 14, 2010 07:06 AM
