Best turbo for torque
Old Jun 7, 2006 | 03:16 AM
saleen281's Avatar
What is the best turbo for low end torque and whp at or around 550-600? I was thinking the AMS gt35r... but what are the other options, and who else makes the kits?
Old Jun 7, 2006 | 03:38 AM
Ang Wen Yan's Avatar
There are no too much of torque on GT35R until 5krpm!!You should consider this:2.3/2.4 + GT35R.This is good enough for 650whp/500wtq.
Old Jun 7, 2006 | 07:24 AM
okevolutionVIII's Avatar
Anything that can spool the fastest will make the best low-mid torque, but it will not hold up at high rpms like a big turbo.
Old Jun 8, 2006 | 01:51 AM
trinydex's Avatar
uhm... if you want 500whp and 500fpt then you need to get something more than 2 liters.
the fact is that in order to produce torque you must maintain exhaust gas velocity.
in order to produce horsepower you must be able to sustain high rates of air mass movement.
these two things are almost mutually exclussive because to flow more mass volume means to use great cross sectional flow area which inevitably slows air. the only way to get around it is to use more air, more displacement.
Old Jun 18, 2006 | 05:56 AM
saleen281's Avatar
ok advise takes 2.4 stroker with ams gt35r
Old Jun 18, 2006 | 06:01 AM
WrX Kila's Avatar
why in the world would you need massive amounts of torque? If you are going to a autocross track than I see, but if you are a highway racer like me torque means nothing. I punched it with a SRT8 in second gear and left him smelling Evo fumes!
Old Jun 18, 2006 | 08:50 AM
SlowCar's Avatar
LOL, evo fumes
Old Jun 18, 2006 | 08:55 AM
Silk's Avatar
I think buschurs RS with their 2.3 and 20G-9 makes something like 480 ft-lbs at like 3800 rpm
Old Jun 18, 2006 | 12:25 PM
Soon2BEVO's Avatar
"high whp" and "low-end torque" is an inverse relationship in the case of our little 2.0Ls. If you want low end torque and that power youre going to need a V8
Old Jun 18, 2006 | 12:33 PM
fromWRXtoEVO's Avatar
Unfortunately you wouldn't find any turbo that would give you a lot of torque at low rpm. Big turbos give you big HP and tq but normally at higher rpms.
You need a set of cams to bring the powerband down and maybe some other mods otherwise a stroker kit or a bigger block.
Carlos
Old Jun 18, 2006 | 12:34 PM
saleen281's Avatar
good cuz my clutch can only handle 400 ft lbs of torque (rating)
Old Jun 18, 2006 | 12:48 PM
spragueevo8's Avatar
Is there any advatage to a 2.3/2.4 stroker kit with the stock turbo???
Old Jun 18, 2006 | 01:17 PM
R33E8's Avatar
full boost at like 2k rpm but the bad things are compressor surge...
Old Jun 18, 2006 | 02:29 PM
Warrtalon's Avatar
What clutch?
Old Jun 19, 2006 | 01:10 AM
saleen281's Avatar
works stage 2
