Axles giving me a hard time
Old Jun 10, 2006 | 01:13 PM
althemean's Avatar
I am trying to get the axles out to remove the t-case. I have the hubs disconnected and the axle is just hanging in the air. I tried to prybar method with the hammer as described in the maint man. They just dont seem to want to budge. Any tips or tricks or should I just pry harder?
Old Jun 10, 2006 | 01:15 PM
smokedmustang's Avatar
Isn't there "clips" in there to remove first?
Old Jun 10, 2006 | 01:16 PM
althemean's Avatar
I thought that those were only on the input shaft on the drivers side.
Old Jun 10, 2006 | 01:20 PM
elhalisf's Avatar
someone has to hold the axle straight as your doing it with the prybar. also have that other person SLIGHTLY yank on that axle as you are prying it with the pry bar.
another method is use the dent puller that you will use for the inside shafts. wrap the chain around the axle end and also have someone hold the axle straight.
key is having the axle straight.
Old Jun 10, 2006 | 01:22 PM
althemean's Avatar
thanks. I had my girl holding the axle but she was kinda scared about doing it. Just have to get one of my buddies from work to help. Thanks again for the tip.
Old Jun 10, 2006 | 01:23 PM
If you get in trouble, I can put you in contact with someone who knows. pm me phone number if you want.
Old Jun 10, 2006 | 01:26 PM
elhalisf's Avatar
also do you have a long and thick enough pry bar? a small one wont work.
Old Jun 10, 2006 | 01:27 PM
althemean's Avatar
I got all the time in the world. There is nothing that can stop me, things just slow me down till I get them figured out. I will keep it in mind Smoke. Thanks
althemean's Avatar
I may have to run out and get a bigger one. I think that is part of my problem. I just wanted to make sure my procedure was right.
Old Jun 10, 2006 | 02:18 PM
rraulston's Avatar
i use a 2 foot piece of 2 by 4 and a 4lb sledge for the driver side and a 2 foot prybar for the drivers side.
shesfelicia16
Dec 27, 2016 09:41 AM
CeliOnce
Feb 3, 2016 11:53 AM
brunz44
Aug 29, 2013 07:32 PM
PedroMartinez
15
Jul 24, 2010 08:44 PM
evolancer04
Sep 1, 2008 04:58 PM
