MR trans suck when cold
Old Jun 13, 2006 | 01:49 AM
  #31
zhemel's Avatar
Originally Posted by SKILMATIC
Damn! a 1.72 60ft? Wow that is pretty incredible actually. Yeah I need to start powershifting when I get my aftermarket clutch. I am just too afraid for some reason on my stocker.
I am sure once I start powershifting that will obviously help my et's
Define powershifting slowmatic.
Old Jun 14, 2006 | 04:40 PM
  #32
trinydex's Avatar
that is normal, it can be solved by double clucthinc into first gear. very simple driving technique.
the reason it happens is because the fluid is not grabbing enough.
more synchroes means more time to sync. it's stronger however.
Old Jun 14, 2006 | 04:42 PM
  #33
trinydex's Avatar
Hmm, when road racing this past weekend in 90+ degree temps, I did notice that my shifting suffered some. I know that's pretty normal, but I wonder if there is a fluid that would perform well under those extreme conditions while being a little notchy when cold. I could live with that as long as it performed well under extreme heat...
this is a bit of a problem... there haven't been definitive reports of a fluid that works well in an mr tranny for high performance situations. the bg stuff is definitely the best for 5 speed.
maybe erik's mopar stuff will be the way to go. but someone must try it first :\
Old Jun 17, 2006 | 02:02 PM
  #34
FCobra94's Avatar
Excuse my "n00bness" but is Synchromesh or Synchorglide from:
http://specialtyformulations.netfirm...x.php?cPath=21
compatable with the EVO 5/6-speeds?
Last I heard, DSM's were using this stuff and had nothing but praise for it...
Old Jun 17, 2006 | 11:02 PM
  #35
Erik@MIL.SPEC's Avatar
The 5 speeds and six speeds like different fluids. I say this based upon the fact that
a) Manyt people with the 5 speeds rave about the BG
b) 6 speeds require 75W-85 GL-4 or EXACT equivalent
c) mine, and a few others I know of, did not have good experiences with the BG and a 6-speed.
Jacks Transmissions
Jacks Transmissions
13
Apr 4, 2013 12:03 PM
mrfred
31
Sep 12, 2010 05:23 PM
Solo II Evo
Apr 22, 2009 03:08 PM
MuslimEvoFreak
Jan 23, 2006 12:29 PM
Ookami
28
Nov 22, 2004 06:07 AM
