help with afr!
Old Jun 14, 2006 | 05:11 PM
Ducu's Avatar
Question help with afr!
guys i have a problem...
I have an Evo IX with HKS silent hipower and an ecutek software!
on my belltronics gtech it shows 390 hp at the crank!!!
i tested an stock s4 with that gtech and showed exactly 344.08 hp... so i was thinking that it might show good!
in that situation...do i need a fuel pump?, maybe im runing lean?...(from ecutek i should be runing on 1.6 boost)
Thanx in advance!
PS. By the way ...i raced on 1/4 mile with the new RS4 (420hp) and i won with 2 cars in front!
Old Jun 15, 2006 | 04:41 PM
thedarkside's Avatar
Well youre definately not actually making 390 crank power. But yes when you get a tune it is a good idea to upgrade fuel. The IXs do have a bigger pump than the VIIIs but its better no to try to run them at a high duty cycle. A 90 dollar Walbro can save you thousands in the long run. Thats just my 2 cents however. The best maintance is preventative maintance.
Old Jun 15, 2006 | 04:44 PM
Ph3n1x's Avatar
Doesnt that gtech make popcorn?
Wouldnt take what that thing says for a grain of salt.
By a Wideband thats a btter investment and as the guy said before the Walbro is cheap and can save u
you shouldnt be running past 1.4 bar with no fuel pump.
Old Jun 15, 2006 | 04:51 PM
Soon2BEVO's Avatar
Throw the GTech in the trash
Old Jun 15, 2006 | 10:28 PM
elhalisf's Avatar
that only holds true for the evo 8's. according to AL, the 9's have a higher flowing fuel pump and he guessed their flow rate to be 230LPH.
P.S: This is my 500th post. I am an evolved member. WOOOHOO
Old Jun 16, 2006 | 12:11 AM
Thats exactly what I said. But running a IX fuel pump past 21 psi you are going way too deep into your duty cycle so throw away the thrashy gtech and get a widenband as suggested cuz they rock and while youre at it a fuel rail isnt a horrible idea either. The stock ones are known to lean the 4th out.
Old Jun 16, 2006 | 12:34 AM
RREvo's Avatar
Offtopic question are you really from Romania?
Old Jun 16, 2006 | 03:38 PM
Gruppe-S's Avatar
The IX Fuel pump is pretty good, with just a reflash and an exhaust you should be nowhere near running out of fuel. If you think you're running lean (because of an improper tune), I would recommend a PLX wide-band 02 system. There's the base model and there's one that will detect detonation also. It's just a great safety feature to have!
As for the Gtech, I'd get on a dyno. That said I think the new PLX's have a horsepower feature also!
Cheers,
Gary
Shameless plug:
http://www.gruppe-s.com/Plx/plxelc.htm
Old Jun 23, 2006 | 04:57 PM
Ducu's Avatar
Thx a lot guys... nice info!
In the meantime i bought a ralliart dropin filter, a helix turbo outlet, a walbro fuel pump and a radiator cap from ralliart ( ...lol).
I need more info about PLX wide-band 02 system...
where do i plug it ? at the outlet o2...or the testpipe one?...or im mixing stuff and i dont know what the hell im talking about?!...
PS. 1.Yes im from Romania...
2.Gruppe-S...do u make shipments all over the world? Like ...Romania?
If so...what payment metod and with what transportation?
hbruce16
For Sale - Miscellaneous Automotive
Sep 13, 2011 06:30 AM
boosten
Jul 12, 2005 12:43 PM
Thoe99
17
Dec 15, 2004 03:57 AM
erioshi
20
Aug 25, 2004 12:23 PM
