OK to go from Synthetic tranny fluid to NON-Syn?
Old Jun 19, 2006 | 08:10 AM
boostedwrx's Avatar
Just wanted to get some opinions... I put some synthetic tranny oil in and first impressions are not as favorable as stock. Im thinking about giving it a few hundred miles before I make my decision but will this only make the transition back to stock more difficult? I understand synthetic fluids fill all the tiny tiny pours of the metal, and I've heard to not go back to dino oil in the motor so what is it with transmissions? Should I get the fluid out right now for OEM or should I give it more time to bead in? I was hoping to make my 2nd gear grind and cold shifting a little better, but now Im getting locked out of 2nd more and my 6th gear is more difficult now. On the OEM fluid, at least everything was smooth once warmed up. Please help!
Old Jun 19, 2006 | 08:23 AM
boostedwrx's Avatar
Also wanted to add that I used an exact equiv to the 6-speed requirements. I didnt want this to turn into a fluid thread but just FYI I used to Castrol Syntorq LT 75w85 GL-4 Synthetic. I just want to know what the best course of action for my tranny should be. (Yea I probably should of left well enough alone...)
Old Jun 19, 2006 | 08:35 AM
TeStUdO's Avatar
I think you should give the synthetic a chance. When I first switched to synthetic it took about 500 miles for me to see a true difference.
fromWRXtoEVO's Avatar
Boostedwrx,
I would like to help you but you are limiting the answer by saying that you don't want to heard what works on other MR's.
I dragged my MR for well over 100 times/passes and since the 20-30 passes I use to miss gears often. This use to happen when reving the engine high. At one point other gears were difficult to engage in traffic during normal driving.
I put GM Shyncromesh and never had any issues ever ever. Shift smoother.
On the other hand, my Evo 9 5 speed tranny was notchy from day one, it was a biatch to engage to second gear and often it was hard to downshft from 5th to 4th to 3rd and so on. Again, GM Shyncromesh fixed all.
You might also want to consider Red line MTL. I hope that helps and sorry if I mentioned what work for me but it might save you big trouble down the road.
Carlos
Old Jun 19, 2006 | 09:24 AM
boostedwrx's Avatar
Interesting... so maybe the oil needed to mate with the metal a little bit to take affect?
Old Jun 19, 2006 | 09:28 AM
boostedwrx's Avatar
Originally Posted by fromWRXtoEVO
Boostedwrx,
Carlos
Sorry I just meant I didnt want this to become another "fluid thread." But thanks for telling me you had success with Syncromesh!
On OEM fluid I could rev the hell out of it and never grind a gear. Everything was pretty much perfect except for the 2nd gear grind when cold (which is why I wanted to try the Syntorq LT)
I'm just worried if I let the synthetic break into the metal, I will have a difficult time if I ever go back to conventional, non-syn OEM fluid. Like in 1000 miles, if the oil doesnt feel any better, I'll most likely want to go back to OEM fluid I just hope using synthetic for that 1000 miles didn't put me in a worse place than I orginal was. Who knows though, maybe in 1000 miles it will be better than OEM....
Old Jun 19, 2006 | 10:35 AM
travman's Avatar
it will be fine, it wont hurt switching back....
Old Jun 19, 2006 | 01:35 PM
boostedwrx's Avatar
Anyone else? bump dity bump bump
Old Jun 19, 2006 | 01:48 PM
WhtEvo05's Avatar
One quick call to Shepherd Racing would give you the answer you need.
Old Jun 19, 2006 | 01:52 PM
boostedwrx's Avatar
I wouldnt want to bug them really though... I hate calling someone who is busy 24/7
Old Jun 19, 2006 | 03:17 PM
Erik@MIL.SPEC's Avatar
Give the oil some time. Wanting to ditch the oil after 150 miles is premature.
Old Jun 19, 2006 | 05:08 PM
boostedwrx's Avatar
After 500 miles or so, the oil will definately be one with the metal. If I still dont like the shifting quality at that point, it will still be perfectly OK to go back to the OEM fluid and get my normal feel back?
Old Jun 19, 2006 | 08:32 PM
EvoG8r's Avatar
I went from BG II to BG I on accident, but it has held up pretty well. I had no problems at the track. The only issue I have is that the fluid doesn't shift as well as BG II under hot conditions.
apagan01
Sep 24, 2014 01:57 PM
Erik@MIL.SPEC
45
Apr 17, 2012 12:01 PM
Pure Playaer
74
Nov 25, 2009 08:17 AM
boostedwrx
68
Aug 28, 2008 07:17 AM
Hcaruso4
Lancer Tranny/Drivetrain Tech
Jul 2, 2008 02:42 PM
