-4/-1 or -2/+1 cam timing? Same LSA. What will be different?
Old Jun 25, 2006, 06:03 AM
Wangracing's Avatar
Hi team,
have been pondering what performance difference there will technically be between these two cam settings. The LSA is the same but the timing is different. What are the likely charateristics of each setting? Fairly familiar with the reviews of the -4/-1 setting but not sure on the effect of the change to -2/+1. Anyone care to theorise?? Thanks in advance.
Old Jun 25, 2006, 08:42 AM
Ted B's Avatar
Same basic smooth idle and moderate midrange response characteristics with broad powerband and a bit less emphasis on peak power (i.e. >5000rpm). This is assuming one is using HKS cams.
Old Jun 25, 2006, 11:16 AM
Viciouslord's Avatar
where can i get more info on settings?
Old Jun 25, 2006, 01:13 PM
Jeff_Jeske's Avatar
The dyno.
Old Jun 25, 2006, 04:56 PM
Wangracing's Avatar
Thanks Ted. Yes this is for HKS (272/264) cams.
Viscious lord, you can try some searches as there are some pretty detailed threads out there with general information on cam timing and some testing of a couple of settings.
JC evo1
54
Oct 12, 2009 07:59 PM
ssteve
May 22, 2009 03:27 PM
ssteve
Apr 20, 2009 10:11 AM
Bonestock!
Gruppe-S Engineering - California
May 23, 2008 07:01 AM
Noogles
49
Jul 25, 2007 08:49 PM
Quick Reply: -4/-1 or -2/+1 cam timing? Same LSA. What will be different?
