Good turbo w/o sacrificing spool
^That is just simply not true before a certain RPM threshould depending on the turbo. You will be hard pressed to find a dyno plot of a gt35R vs a 16G that makes more power than the 16G before 4k or so, that is the price you pay for the extra 200whp of potential.....
He is right on the money however with the 50 trim, they are probably the best pump gas snail out there.
*** dyno lies to you..... if the car made the same or more power with less boost woudlnt your *** dyno be telling you its faster????
Scorke
Scorke
That is ttrixes 50 trim with all supporting mods on there dyno... a nice piece of kit as the results show, and I guarantee you it will spool 1000-800 rpm quicker than the smallest ATP kit.
Here is another 50 trim, same kit same dyno different results.
Scorke
50 Trim should make full boost around 4000-4200 rpm from what I have seen (AFAIK), to be honest if your really just craving a beast of a car to drive around town, do a 2.3 and a 50 trim and you will be overjoyed.
Scorke
Scorke
Originally Posted by WrX Kila
I said it before and I will say it again 3076r and finish.
Originally Posted by scorke
^Yeah but they should be sure not to buy one like yours, which have proven to not make power....
Scorke
Scorke
So you wanna reference that ONE guy in Florida with the compression issue. Forget about the other 10 people that actually made power with this kit.
Show me people who made good/decent numbers with it, I havent, where as with the ams/ttrix kit I have seen countless good results....
Yes I have been in a 50 trim powered car. I drive a 3076 powered car.
Why don't you share with us how stellar this kit was on your car?
Scorke
Scorke
Who cares, even if his super duper ATP kit made 380 whp, 380whp and 320 tq is flat out poor from any aftermarket turbo on anything but pump gas......even on pump gas that tq number is low, indicicates slow spool.
I honestly do not know how you could be satisfied with 320 ftlbs of tq on a semi race gas tune.....
Scorke
Scorke
Was that 430 on race? My numbers there were on 20 psi on pump. Now I am not one to make excuses but on the dyno at top speed doug reckoned it wasnt fully broken in, and that somthing was up because after 18 psi it wouldnt make any more power. After putting some miles on it it feels quicker now, sounds different and doesnt shut down instantly, I will be going back on a dyno shortly, one pump gas map and one 110 map, I'll let you know how it turns out. II might just have a 35R by then but who knows.
Scorke
Scorke
Scorke
Scorke
Originally Posted by Gruppe-S
For me personally the ultimate balance in drivability versus power would be a 2.3 stroker motor with a GT3076. Expect to see about 340whp on pump gas and 415whp on race gas (our mustangdyne awd) with very decent spool-up and response times.
Cheers,
Gary
Gruppe-S
Cheers,
Gary
Gruppe-S
And besides, if the 3076 is not enough after trying it, a 35r is still an option at that point. Any info on boost threshold would be appreciated. I'd search for it, but I get the impression you've run this on more than one car, and that makes for better data. Thanks
