Built motor or Turbo kit first
I went the turbo route first as well. So long as your engine shows good compression numbers and seems overall healthy, I would just do the turbo and enjoy it for a while
You can always build the motor at a later date. The stock bottom end can easily support 500+whp. Your never going to get that on pump gas anyway, so you can just run 4-450whp on pump daily, all day, every day. And then for the fun times use the alky/race fuel. The engine should have no problems sustaining this power for semi-prolonged periods of time just fine.
Do the motor first, because if your going w/a 2.0 you don't want to buy a new crank (or block) when it fails.
Do both together to get a good package price on parts and labor, and especially save on the cost of the turbo install. Should save you a minimum of $1000. That's what I did.
If you tend to worry like I do, save yourself the stress that comes from driving around with a GT35R'd motor making 400-500WHP on stock internals (stock bearings) and wondering when your next 28 psi pull to redline on race gas will spin a bearing and send a rod through the block. Sorry to sound so dismal, but it helps to have someone play devil's advocate. Byuild it first and boost with some peace of mind.
Here is a deal with $1500 off the price of turbo kits.
https://www.evolutionm.net/forums/sh...hreadid=212459
Wow...that's damn good price.
LancerRacer01
Jun 22, 2016 01:34 PM
nperkins
25
Apr 13, 2010 08:02 AM
PedroMartinez
12
May 15, 2007 06:10 PM
hacellular
53
Feb 20, 2007 10:37 AM
