shifting problem
shifting problem
so everytime i go from 1st to second at redline, it grinds before it goes in and sometimes it wont even go in. i have the clutch pedal all the way down..for sure. same when i go from 3rd to 4th. now, i have to shift a little slower for it to go in which is giving bad times on the 1/4. i have a stage 2 exedy. i dont know what the problem can be.. any advice?
i'd try adjusting your peddle travel to the proper increments before writing off the synchros. also, check the condition of your underhood shift bushings, assuming you haven't replaced the stock rubber ones with brass or polyurethane, sometimes they tear and cause not going into gear conditions. if both of those are fine www.sheptrans.com cause it's time for a rebuild.
d-sport
Oct 27, 2016 11:51 AM
Richard.Son
Apr 24, 2016 10:10 PM
leonard_shelby
23
Mar 31, 2008 04:57 PM
