Hole in transfer case from exhaust...Help
Old Aug 10, 2006 | 01:05 PM
RaNGVR-4's Avatar
i call UBER BS that is almost completely impossible. if it really did melt, it was from internal heat, not external heat.
Old Aug 10, 2006 | 01:14 PM
jhill299's Avatar
Is it just me or wouldn't your 1/16" down pipe melt and fall off before it got hot enough to melt a hole in 1/4" t-case???
Old Aug 10, 2006 | 01:15 PM
Ev0ikon's Avatar
I also think it's not possible to melt the housing from the exhaust. Please post pics to prove otherwise.
Old Aug 10, 2006 | 01:25 PM
RevMoto's Avatar
<img src="http://img137.imageshack.us/img137/5305/43630074mm2.jpg"</a>
<img src="http://img118.imageshack.us/img118/8384/43630079mb1.jpg"</a>
Old Aug 10, 2006 | 01:31 PM
JDMevoBOOST's Avatar
Bad fitment on dp caused rubbing.....especially when the dp is probably vibrating like crazy anyway and while under load and shifting.....happened over time so u should have been informed
RevMoto's Avatar
Pic sucks but you get the idea.
Old Aug 10, 2006 | 01:34 PM
RevMoto's Avatar
Correct, the first time I brought it to the dealer they said everything checked out fine. Meaning they probably didn't look at it. How can you not notice the fluid everywhere. They also said it ate through a power steering line. This definitely happened before I brought it to them. But they still should have seen it.
Old Aug 10, 2006 | 01:36 PM
WrX Kila's Avatar
How can a downpipe put a hole in the transfer case?
Old Aug 10, 2006 | 01:38 PM
RevMoto's Avatar
Apparently it can. I would have thought the downpipe would have a giant hole in it way before the transfer case would have. Oh yea and the fluid that leaked out got all over my axle boots and melts them. Yea that's right.
Old Aug 10, 2006 | 01:49 PM
Ev0ikon's Avatar
Pics are too blurry for me to see anything.
The only logically expaination is that the DP physically rubs/bangs the housing of the Transfer case enough time to slowly chip it off.
Old Aug 10, 2006 | 01:56 PM
speedracer2169's Avatar
well either way that is going to be a real tought call. What are the egt's that the car is giving off? What else was modded to it?
Old Aug 10, 2006 | 01:58 PM
RevMoto's Avatar
Just exhaust.
Old Aug 10, 2006 | 02:05 PM
TTP Engineering's Avatar
Downpipes can rub and vibrate a hole in a transfercase.
It has nothing to do with heat.
Old Aug 10, 2006 | 02:11 PM
*sam*'s Avatar
What brand is the DP?
tweakdsm's Avatar
read your pm
