Is it Blown?
Old Aug 17, 2006 | 10:36 AM
  #31
sr20det91's Avatar
The bottom end should be fine, your main concern is if the head got warped which it probably did. I pulled the head on a friends car that had overheated very briefly due to fan failure and the head had to be resurfaced and obviously a new hg installed.
It sounds like your failure was caused by the infamous hose failure on the 05's where the coolant line runs through the turbo. Your dealership should realize this and replace everything under warantee. A simple compression check should be able to let you know the extent of the damage. There is really no way of knowing if its just a hg failure or a damaged head. The head needs to be pulled reguardless.
In my experience if it heats up bad enough to ruin the hg, the head is probably warped as well.
Its very strange to me that they said they were gonna have to change out the exhaust, as that make no sense at all. Coming from the dealership though it does not surprise me.
Old Aug 17, 2006 | 11:06 AM
  #32
EVIL_EVO_VIII's Avatar
Mine overheated 2x and i had a compression test done and it 3 and 4 were leaking.. I had them take the head off and had it sent to a machine shop were it was checked and it was cleaned. After a new hg install, another test was done and all 4 checked out the same. So its possible its only the hg that got damaged with his car but then again the head still can get warped.. I had the pistons checked also
Old Aug 17, 2006 | 12:11 PM
  #33
h.funk's Avatar
TTP Portland Oregon
Old Aug 17, 2006 | 12:18 PM
  #34
C6C6CH3vo's Avatar
TTP is in Fl, give Horsepowerfreaks a call
Old Aug 18, 2006 | 02:54 PM
  #35
h.funk's Avatar
My best option is to probably sell the damn thing!! Lemon!
Old May 28, 2007 | 04:45 PM
  #36
jkim2001's Avatar
subscribed
Dallas J
Jan 15, 2017 03:52 PM
ptm5070
21
Nov 5, 2015 05:19 AM
redline38
Jun 21, 2012 09:02 PM
erioshi
Mar 29, 2010 03:39 PM
browningderek
Oct 15, 2009 11:38 AM
