new intercooler installed now a noise pleas help
Old Aug 18, 2006 | 09:01 AM
aznxdragon30's Avatar
Ill check with Luis on this if the gasket was swapped out when the turbo was..
Old Aug 5, 2007 | 06:18 AM
jucelavri's Avatar
I have the same sound...any other suggestion.
Also, In where did you connected the hose that came out of the black OEM tube that came out of the turbine?
Old Aug 6, 2007 | 10:58 AM
with my issue mine was the Greddy lower IC pipe was warped so even with the gasket there it made the noise.. so as of now i put the stock lower pipe and noise is gone..
Old Aug 7, 2007 | 06:16 AM
spln*up's Avatar
my friend had this same problem. it was the gasket at the j pipe
Old Aug 7, 2007 | 02:01 PM
jucelavri's Avatar
guys...I just change the gasket on the J pipe from the Greddy kit to the oem and problem solve.
Pavien
Feb 12, 2016 01:18 AM
nonojoe66
Oct 27, 2009 10:47 PM
Evoryder
Feb 1, 2008 03:59 PM
ultraflip
Apr 29, 2005 02:58 PM
ku7484
Apr 12, 2004 05:09 AM
