Do i have an Upgraded Fuel pump?
Old Aug 22, 2006 | 09:47 AM
gregfromblur's Avatar
Question Do i have an Upgraded Fuel pump?
Hey guys! This Thread is for a buddy of mine. Just got a used 03 Evo. Basic mods cams on the car, including a FLASHED ECU. I was telling him to get an upgraded fuel pump, to keep it on the safe side, but i started thinking/ What if he already has one? Is there a way we can easily check to see if he has one or not? I have a Walbro in my Evo, which i can hear slightly, but another friend has the same pump, and we cant hear his at all. any ideas?
By the way, i tried to search this, but it was hard, and returned no helpful results.
Old Aug 22, 2006 | 09:50 AM
Torre from Va.'s Avatar
I've always gone of off sound, but I would change to be on the safe side, we recommend changing the pump every 30K or every "season"
bolsen's Avatar
Pull it out and look.
Old Aug 22, 2006 | 09:51 AM
Yea, it seemed like that was the only option, but we were trying to avoid that if possible.
Old Aug 22, 2006 | 09:52 AM
Yea, so did i, until our other friends doesnt make a sound at all. Usually i hear mine when the key is on ACC, if i lean down by the back seat, i can hear mine. my buddies is a totally different story.
Old Aug 22, 2006 | 09:56 AM
TeStUdO's Avatar
Takes about 15 minutes. Just make sure the gas is really low and you wont even make a mess.
Old Aug 22, 2006 | 09:59 AM
Smike's Avatar
Drive in until it is out of gas (1/8 tank). Take out lower rear seat (2 clips) the WB255 should be easily heard.
When you have a full tank or it is submerged it will be quite.
Old Aug 22, 2006 | 10:03 AM
hotrod2448's Avatar
Do you have anyway of checking fuel pressure? I noticed my fuel pressure changed quite a bit from stock pump to Warlboro.
Old Aug 22, 2006 | 10:04 AM
Yea We'll give that a whirl then. I suppose once the gas light turns on, we can check and see if we hear the tell tale whine. Hope his gas light not broken.
Old Aug 22, 2006 | 10:06 AM
No Fuel pressure gauge on hand.
WRCturbo
Feb 16, 2023 04:53 PM
lonniee23
Dec 14, 2021 08:31 PM
Tyrel Bursaw
Jul 23, 2018 02:26 AM
mrevo10
Sep 6, 2016 12:36 AM
Ultimate Racing
EvoX 'For Sale' External Engine / Power
18
Oct 25, 2011 04:38 PM
