CEL Fix / O2 Simulator on IX
Old Aug 28, 2006 | 05:53 AM
  #31
robb86's Avatar
Fouler/Spacer FTW!
Old Sep 22, 2006 | 05:17 PM
  #32
SP00LIN's Avatar
Originally Posted by daisaw1219
The perrin one doesnt work on Evo Ix. Use an anti fouler....its 5 bucks and it works better and no cutting or splicing of wires required.
Is there anyone out there that got the Perrin to work on a IX?
Old Sep 23, 2006 | 01:10 PM
  #33
americanwit's Avatar
fouler works well
Old Sep 26, 2006 | 11:47 AM
  #34
SP00LIN's Avatar
Well to answer my own question - I got the Perrin o2 sim to work on my IX. Went in under the seat. Spliced into the wires & soldered everything together. It's working great.
Old Sep 26, 2006 | 12:24 PM
  #35
rogue's Avatar
what size anti fouler did you use? 18mm?
i am trying to find a way to plug an extra 02 sensor hole on an exhaust.
Old Sep 30, 2006 | 09:26 PM
  #36
SophieSleeps's Avatar
What did you find the wire colors to associate to?
power, ground, signal, heater
Old Sep 30, 2006 | 10:44 PM
  #37
SP00LIN's Avatar
The simulator came with instructions and which line to splice into. I just followed the instructions and it worked perfectly.
What I did was remove the passenger seat. Then I stuck my hand under the carpet and pushed the o2 sensor wires out of the little cut out in the carpet next to the center console. Look for where the two wires connect and unplug them. You want to splice into the wires that lead into the car and not the wires that go out of the car to the o2 sensor. All the wires you need are in that one line. The center console with the cubby pocket will need to come off so you can remove the seat. This exposes the emergency brake assembly. You can ground it there.
Old Mar 4, 2007 | 09:57 AM
  #38
80210's Avatar
Where did you buy your perrin cel fix?
Old Mar 4, 2007 | 10:28 AM
  #39
Bobrick's Avatar
Use a engine drain plug.
Old Mar 4, 2007 | 11:22 AM
  #40
GBEvo's Avatar
My Perrin O2 fixed worked great for a year. Just threw a CEL last week and it was for the rear O2. Checked the mechanical fix and no wires came loose, it is still blinking. Any suggestions?
Old Mar 4, 2007 | 07:14 PM
  #41
SP00LIN's Avatar
It was a while ago, but I think I got it off e-bay.
Old Jun 28, 2007 | 02:07 AM
  #42
4g63er's Avatar
-Deleted-
THUB
Sep 6, 2008 12:28 PM
EricR
Apr 25, 2006 02:43 PM
thatsMR2u
Feb 12, 2006 12:51 AM
zstryder
25
May 27, 2004 01:21 PM
Bitnode
Lancer Troubleshooting
May 1, 2003 06:31 PM
