The reason you MUST do a "boost leak test"!! Don't pass go. Read this.
Old Nov 9, 2006 | 07:35 PM
  #106
kiddevo's Avatar
I did test and hear air coming out. sounds like its by turbo but can't find leak. used soapy water and put hand all around . What can it be ? NO bov cause it goes on intake.
Old Nov 10, 2006 | 09:48 PM
  #107
mitsuorder's Avatar
How many miles do you have on the turbo? My turbo's seals went around 35k...
Old Nov 11, 2006 | 07:27 AM
  #108
kiddevo's Avatar
brand new 3076R. can the air i har be bleed off air from motor?
Old Nov 11, 2006 | 07:45 AM
  #109
mitsuorder's Avatar
Yes, if the motor is cold you will get blow by past the rings. Do the test with a warm motor while everything is still seated up.
Old Nov 11, 2006 | 10:18 AM
  #110
kiddevo's Avatar
ok thanks i will try after running.
Old Nov 11, 2006 | 04:24 PM
  #111
Blue Evo 8's Avatar
I finally did a boost leak test on my EVO today and found NO LEAKS!!!!
I looked around, listened, felt around all the connections/piping with my hands and ears and everything was kosher, even with 20 psi going thru the system.
well, my MBC vacuum line had a small leak since I didnt zip tie it, so I double zip tied it ha ha
Old Nov 11, 2006 | 05:05 PM
  #112
EVIL_EVO_VIII's Avatar
Did a boost leak today and did not find one at all
Old Nov 11, 2006 | 05:31 PM
  #113
nj1266's Avatar
Could someone show me how to do a leak test? Is there a how to somewhere for the Evo?
Old Nov 11, 2006 | 06:21 PM
  #114
got boost??'s Avatar
maybe this will be a dumb question but here it goes.
Doing the boost leak test, you only have to connect the hose with the valve steam to the turbo inlet and pressurize the system including the intake manifold, isnt it??
if valves at any cylinders in the engine are in overlap, wouldn't pressure drop because of this???
Thanks, and dont flame me.
BTW:
here yo go
Boost leak test
Old Nov 11, 2006 | 06:42 PM
  #115
kjewer1's Avatar
A valid question. The motor likes to stop in certain spots, due to valve spring tension. You'll notice this if you've ever rotated a motor by hand. In countless boost leaks tests on this car and the DSMs, I've never had one stop in overlap.
Old Nov 11, 2006 | 07:05 PM
  #116
OHHHH, ok, got it. Like when you move by hand an engine sometimes tends to spin faster, thats like when a cilinder had just finished the compression stroke.
Thanks a lot.
Old Nov 12, 2006 | 07:25 AM
  #117
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Should be tested up to 30psi.
Old Nov 12, 2006 | 11:06 AM
  #118
EvoTio's Avatar
What boost leak tester do you use? The Home Depot tester I made up started to balloon pretty good at 25 PSI. I didn't trust it to go any higher.
Old Nov 12, 2006 | 04:14 PM
  #119
eficker's Avatar
good post
Old Nov 13, 2006 | 07:16 AM
  #120
David Buschur's Avatar
It's odd to me that a 6 psi drop in boost pressure on the dyno graph wasn't a sign it had something wrong with it.
It's 4 hours from Indy to Ohio and 6 psi drop would have been detected, checked and fixed.
To each their own.
