The reason you MUST do a "boost leak test"!! Don't pass go. Read this.
Originally Posted by smokedmustang
I have the autometer boost gauge, and had someone sit in the car, until the boost gauge read 23psi, and HELD that number, without bleeding off any pressure (leak). I had to get my air tank up to 100psi in order to raise the boost levels gradually to 23psi in my case. ALL my leaks were evident before that though. your hoses will balloon, and you will hear a hiss, or see the boost gauge not "hold" the boost, meaning it is leaking out somewhere. listen carefully. car off.
Originally Posted by idriveaevo
but how did your gauge read boost when the throttle is closed??? and your saying you had to pressurise your intake system to 100PSI?!?!?!
I tried to pump (with a bike pump) up to 23 psi, on the bike pump gauge. that wasn't pressure enough to get the air in the system, and "charged". I needed 100psi in the can, and started to pump the air in the system, and someone was in the car, as to NOT over fill the system with any more boost than the turbo could handle, or you could blow out seals etc.... It took a minute of pumping the air in from the "air can" to get to the desired pressure on my cars boost gauge (23psi) once we got there, we stopped filling the 'system' with air. the air tank gauge read 10psi when we got done charging the system.100psi in the air tank: (usually seen at autox's) a can, a gauge, and a stem to fill up car tires. Purchaced at Walmart for 25 bucks, filled up at a gas-station. you want to keep a watchful eye on the boost gauge. It might depend on where you have the boost gauge tapped in. I will go see where mine is tapped into. Maybe for the purpose of this test, you would have to "re-T" the line further down the line. Anyone have input on this? Be back later, when I find out where I am "T"ed in.
b/c the throttle body is never 100% sealled when the throttle is closed if is was no air could enter the motor and it would not run....
edited
Originally Posted by matt55
How does a your car idle when the "throttle is closed" ?
b/c the throttle plate is never 100% closed if is was no air could enter the motor and it would not run....
Anyone else having problems holding pressure while testing due to air seemingly blowing by through the crank case? I have heard that you should bump the starter to get all valves where they need to be in order to hold pressure. 13-0 and I could both hear pressure blowby when we put our ears to the oil fill hole on the valve cover.
There will always be some leakage into the crank case, especially if you are doing the test cold. In my experience, even with a very good motor, you can get a lot of leakage out the valve cover due to the PCV valve. I've always eliminated that POS, but I've yet to do it on this car.
The throttle is actually 100% closed. The air is bypassed via the ISC, FIAV, and BISS.
Originally Posted by VTECH8TR
Kevin,
I don't understand why AMS or the other tuner did not check this for you. Especially after the long drive to get tuned, the long wait etc....
The Boost Leak test should be done anytime you change ANYTHING on the car.
Exactly....this one one of the first things I learned when dealing with a forced inducted car (DSMs to start).
Well I was fixing the boost leak around my BOV and tore the darn gasket. I tried to pit back on with some RTV and get a nasty whistle at High boost. Anyone know if the roll-o-gasket material at Advance auto and such will work? Either that or black RTV is going to have to do!!
I find it interesting that the owner is willing to take responsibility for his actions and words, which is a rare thing these days, and everyone still wants to hang the shop by its *****. I mean, you can pay the shop at thier standard labor rate to do a boost leak test, but it is certainly not thier responsibility.
