watery/oily mix in catch tank
Old Mar 1, 2002 | 04:44 AM
N.Ring's Avatar
Checked my breather catch tank and noticed a rather watery/oily solution in it. More water than oil!
Could this be condensation in the catch tank? Oil in the oil pan looks fine.
Can the engine breather dump coolant as well??
Old Mar 1, 2002 | 04:49 AM
TearItUpSports's Avatar
Is it just water, or specifically radiator coolant?
Open your radiator cap and see if there is oil on the surface of the coolant.
If coolant and oil are mixing, you likely have a warped head or bad head gasket or both.
Old Mar 1, 2002 | 08:10 PM
N.Ring's Avatar
no, no engine trouble. It seems to be condensation. Someone told me it is quite normal.
Old Mar 3, 2002 | 12:24 AM
Michaelk's Avatar
Just read this, I would have also said it's condesation. The tank gets hot and then cools down and the other way round. Through that you get condensation, also the temperature changes when the car is stationary.
BaumBizzle
17
Sep 24, 2012 11:59 AM
Evokid8
Jun 16, 2009 12:20 AM
MitsuJDM
Mar 6, 2009 09:12 AM
da_yo
Dec 14, 2008 09:44 PM
CarFanatic
16
Jun 16, 2006 11:04 AM
