HELP!!..Forge Unos MBC
Old Sep 5, 2006 | 06:06 PM
daboi's Avatar
Exclamation HELP!!..Forge Unos MBC
I just got my MBC today and don't have a clue on how to install it so if anyone have installed it before pls give me instruction or even picture on how to do it........thanks..
daboi
Old Sep 5, 2006 | 09:49 PM
Anthony.L's Avatar
Did the Forge not come with some instructions? I would also check the how-to section, that's where I found all the info to install mine. here's a diagram I found in the how-to's that was really helpful to me installing mine this past weekend. Works perfectly!
Yes the diagram says Hallman but all MBC hook up the same way. The key is getting the vacumn and waste gate orientation correct.
Old Sep 5, 2006 | 10:07 PM
SP00LIN's Avatar
I was going to mount my UNOS on the front bolt of the stock air box. The problem is that it gets too hot around the radiator fan that it makes the UNOS extremely hot. I need to find a better spot. Any suggestions?
Old Sep 5, 2006 | 10:20 PM
TTP Engineering's Avatar
I would use the nipple from the turbo outlet for pressure source over the bov.
It has worked the best for us in this configuration.
Old Sep 5, 2006 | 10:27 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
HTML Code:
Old Sep 5, 2006 | 10:28 PM
xenoturkey's Avatar
Agreed.
Old Sep 5, 2006 | 11:08 PM
Anthony.L's Avatar
Interesting, I've read from several people that using the turbo outlet can give you inconsistant boost. I noticed this myself with the stock electronic boost controller and vacumn configuration.
Old Sep 6, 2006 | 12:00 AM
daboi's Avatar
were do you mount the Unos??
daboi
Oct 1, 2006 06:55 AM
evolrobert
Sep 11, 2006 03:13 PM
Aux.
Dec 21, 2005 08:45 AM
Rcebowl
Sep 13, 2005 05:47 PM
krafty
Dec 27, 2004 05:52 AM
