Official torque specs thread
Old Feb 17, 2010 | 07:30 PM
  #61
D-Mon3y69's Avatar
Hey i need the specs for the bolt on top of the outer tie rod, the outer tie rod, and the inner tie rod? Anybody know that?
Old Feb 17, 2010 | 07:37 PM
  #62
D-Mon3y69's Avatar
I found this...
Front axle crossmember bar bolt
49 ± 10 N⋅m (37 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Rear)
167 ± 9 N⋅m (123 ± 7 ft-lb)
Lower arm to crossmember connection bolt (Front)
186 ± 10 N⋅m (138 ± 7 ft-lb)
Lower arm to knuckle connection nut
108 ± 10 N⋅m (80 ± 7 ft-lb)
Stabilizer bar bracket bolt
39 ± 5 N⋅m (29 ± 3 ft-lb)
Crossmember to body connection bolt and nut
Crossmember bolt
Rear roll stopper connection nut
52 ± 7 N⋅m (39 ± 5 ft-lb)
Stabilizer link bolt
Stabilizer bracket bolt
21 ± 4 N⋅m (16 ± 2 ft-lb)
Steering gear and joint connecting bolt
18 ± 2 N⋅m (13 ± 2 ft-lb)
Steering shaft cover bolt
5.0 ± 1.0 N⋅m (44 ± 9 in-lb)
Tie rod end to knuckle connection nut
25 ± 5 N⋅m (19 ± 3 ft-lb)
Old Feb 19, 2010 | 10:11 AM
  #63
EVOlute GSR's Avatar
Dam, this is very well made. Thank u OP.
Old Mar 5, 2010 | 11:35 AM
  #64
Svendiesel's Avatar
Im going to be replacing one of my rear hub/bearing assemblies, anyone have torque specs for the bolts in this area? Thank you!
Old Mar 8, 2010 | 04:03 PM
  #65
v-manracing's Avatar
just did cam install, I torqued the cam bearing caps to 25 FT LBS I see the specks in this thread calls for 15 FT LBS did I torque it too much? should I re torque it or will it be ok?
Old Mar 8, 2010 | 04:05 PM
  #66
EvoDan2004's Avatar
i do mine at 23.
Old Mar 8, 2010 | 04:07 PM
  #67
so 25 ft lbs should be ok with risk of damage?
Old Mar 8, 2010 | 04:13 PM
  #68
EvoDan2004's Avatar
i dont want to be the one to say your ok. but before this thread was made it was 22 ft lbs. i would say your fine.
Old Apr 4, 2010 | 10:26 AM
  #69
Boost_Inspired's Avatar
very useful thread
Old Apr 9, 2010 | 10:01 AM
  #70
LV///R's Avatar
I've been searching for sometime, and I'm wondering how much torque for a oil temp sender install. I'm using one of the plugs right above the oil filter. I can get pictures if needed.
Any help would be appreciated, and sorry if I missed it.
Old May 14, 2010 | 04:18 PM
  #71
littlejap33's Avatar
thanks very helpful
Old Jun 17, 2010 | 07:29 PM
  #72
BlueEvo8JDM's Avatar
perfect! i need tha! thanks!
Old Jul 24, 2010 | 10:03 AM
  #73
EvolutinIX's Avatar
Thanks for the info! Is the mivec cam gear bolt 65ft/lbs as well?
Old Jul 31, 2010 | 04:40 PM
  #74
R/TErnie's Avatar
What is the torque on the wheel bearing assembly? There are four bolts that bolt the bearing assembly into the knuckle.
Old Jul 31, 2010 | 06:45 PM
  #75
boostedwrx's Avatar
I can give you the good FSM CD if you need dude.
