The notchy tranny feel
Old Sep 14, 2006 | 09:22 AM
  #31
S2Kstephen's Avatar
I had the same problem with my '05: notchiness and less than smooth as butter shifting.
What I did to COMPLETELY fix the problem:
BG Syncroshift II fluid...silky smooth all the time, even when its chilly outside
Agency Power short shifer and bushings...keeps it nice and tight(the way we like it
Ingalls Engine dampner...really stiffened the driving...made the car feel WAY more complete
I had been running Motul fluid, but it only lasted about 3k miles before the notchiness came back.
Old Sep 14, 2006 | 05:09 PM
  #32
4g63t28's Avatar
Originally Posted by 4g63t28
I have the same problem with my IX. I got a greddy shiftknob and that helped a little. I just got my WORKS clutchline in the mail today. I'll repost after I install the line and remove the restrictor pill.
Today I installed my clutchline and removed the restrictor pill from the slave cylinder. Unfortunately my hands were too big to thread the banjo bolt back onto the master cylinder and now there's a dozen crush washers under the brake booster, so I borrowed some smaller hands. After I bled the clutch and wiped all of the blood and brake fluid down I took her out for a test drive.
There seems to be a titch more freeplay in the pedal. It's much easier to engage the clutch pulling out of intersections and all of that kind of stuff. More importantly the notchiness is virtually non-existent. The overall shifting has drastically improved whether normal driving, or speed shifting.
I would definatley recommend a clutch line and restrictor pill removal for some first mods. It fixed two of my only three complaints with the car.
Old Sep 14, 2006 | 05:39 PM
  #33
RRRS's Avatar
i used the WORKS line too, it's a nice piece. try bleeding the clutch again, make sure to push/pull the pedal slowly. my clutch pedal feels exactly as it was + the great shifting action now.
Old Sep 14, 2006 | 05:46 PM
  #34
4g63t28's Avatar
I used a vaccum bleeder, but I'm debating bleeding it the good ol' manual way.
Old Sep 14, 2006 | 05:53 PM
  #35
Doogie Howser's Avatar
Originally Posted by Seranin
I realize that "notchiness" is subjective, but my new IX (5-speed) feels this way as well... shifting too quickly from 1st to 2nd and sometimes 2nd to 3rd will yield a grind or crunch sound/feeling. i've learned to pause for a moment in neutral during a shift throw, as mentioned above. I may eventually try the "band aids" but am going to give the tranny some time to wear (~2,000 miles now) first
Well I can let you know that after 5k the the trans did shift much better especially on the 2-3 shift, but flushing the fluid, replacing the weak pos engine mounts and putting on a stiffy will really cure the problem.
It would also be a good idea to adjust the clutch pedal, check out evomoto.com for a detailed how-to.
Old Sep 14, 2006 | 05:56 PM
  #36
RRRS's Avatar
i never tried a power bleeder. i bought a speedbleeder instead. still it was pita, 4-5 reps on the pedal and back up to refill the reservoir. someone on here mentioned the slave cylinder might trap air and recommended to pump the pedal slowly to give the bubbles time to move.
Old Sep 15, 2006 | 03:13 PM
  #37
Seranin's Avatar
thanks for the tips
Old Oct 22, 2006 | 12:43 PM
  #38
Chemwarrior's Avatar
What is the difference between the bushings that go on the shifter and the bushings that go in the engine? Is it beneficial to replace both of them or is it not necessary?
stunt2
Apr 10, 2013 12:11 PM
Sinbig
13
Jan 14, 2012 07:08 PM
EV0lut10n_8
52
May 24, 2006 07:04 PM
Evo_Jay
13
Aug 24, 2005 06:07 AM
Fireball
31
Jan 2, 2004 07:33 AM
