Clutches for the $...
Old Sep 13, 2006 | 11:56 AM
CtSilver03Evo's Avatar
long story short.. My tranni broke due to clutch issues... Luckily the tranni can be salvaged, but the clutch needs to be replaced. I had an ACT clutch on there, but I need to replace the clutch.
What is the best clutch for the $???
1) ACT
2) Exedy Stage 1 Organic Material
3) Exedy Stage 2 Cerametalic
4) Others????
Thanks.
Old Sep 13, 2006 | 01:54 PM
superflyevo's Avatar
i got my tilton in the other day i love it
Old Sep 13, 2006 | 01:58 PM
AZ EVO IX MR's Avatar
i have a ats triple carbon and love it. 1.6 to 1.7 60' every time and daily drives better than any other that i have driven, exedy single and exedy twin carbon,
down side is the price though.
Old Sep 13, 2006 | 02:00 PM
that and you half to warm it up every time you want to beat on the car
Old Oct 15, 2006 | 04:52 AM
EVOLVEU's Avatar
what about the Exedy stage 2 Organic??
Old Oct 15, 2006 | 05:08 AM
turboDan's Avatar
x2 for tilton. Shameless plug,CtSilver03evo,I have one of those tiltons F/S and also from ct,
pm me if interested as I can give you a good deal,cash and carry.
Old Oct 15, 2006 | 05:36 AM
EvoGLH's Avatar
You mean Exedy stage 2 Cerametallic?
I have a Ralliart cerametallic clutch (virtually identical to a Exedy #0592 stage 2)
CtSilver03Evo - what was the tranny issue that took out it out? Cerametallics are more like on-off switches, and will be a bit harsher on the drivetrain because of their lack of slipage.
Old Oct 15, 2006 | 05:46 AM
Ultimate CC's Avatar
I don't have too much experience with other clutches but between the act and the exedy twin plate, I would definitely take the twin plate...
Old Oct 15, 2006 | 06:20 AM
C6C6CH3vo's Avatar
I just bought an Exedy single for $390, definately not an overkill for the application but I'll see how it does soon.
If it works out then $390 aint bad at all, but fast spooling stock turbo combined with alc induced torque at lower RPMs has me worried. If at low enough RPM, it doesn't take much torque for a modest clutch that can hold well up top to slip
Old Oct 15, 2006 | 06:29 AM
EVOLVEU's Avatar
Are you installing it yourself?
Old Oct 15, 2006 | 07:25 AM
EVOLVEU's Avatar
1) ACT
4) Others????
Thanks.
I have the same question. I want a good clutch for less than $600. Theres gotta be one out there.
Old Oct 15, 2006 | 07:50 AM
TurboSpoolinIns's Avatar
I actually like my 6 puck ACT quite a bit. Easy to drive and I know it'll hold at least another 300+ ft/lbs than what I'm making.
Old Oct 15, 2006 | 07:53 AM
C6C6CH3vo's Avatar
I got the Exedy single from GSC and it's a typical kit that includes, disc, pressure plate assy, release bearing (same PN as stock), and guide. It's rated 80'/lbs above stock and since my car is about 90'/lbs over stock then it should work fine. It just depends on at what RPM is it rated 80 over, but anyway $390 for parts I got is a deal no matter what, it should hold fine (I'll know by next week).
The one I got isn't shown at the GSC site but a call to the boss or one of his wiseguys will find one
Old Oct 15, 2006 | 07:56 AM
Paul Nelson's Avatar
id give the horsepowerfreaks feramic 6 puck a try
http://www.horsepowerfreaks.com/pric.../Feramic_-_EVO
Old Oct 15, 2006 | 08:35 AM
RogueSTi's Avatar
I absolutely LOVE my Exedy Twin, but I hear great things about the Tilton. If I ever get another bad **** racing clutch, I'll probably give Tilton a try.
