Car wont start after O2 sensor installed
Old Sep 16, 2006 | 01:38 PM
702RSevo's Avatar
Ok yesterday i had my o2 sensor bung welded into the o2 housing for my gt35r buschur kit, i installed the o2 sensor back into the o2 housing and put it back on the car then took the neg battery terminal off the car to reset the ecu and i went to go start it and the car wont start. It turns over but just wont start up. I made sure i didnt leave anything unplugged and nothing was missing. HELP! this is my only mode of transportation. (before i had the bung welded i just had the sensor in the hole where the bung now is and the car was fine.)
Old Sep 16, 2006 | 01:46 PM
Roberto's Avatar
Check the fuse for the ECU and see if it's blown. If it is, and it keeps blowing everytime you attempt to start the car with a new one, then you may have dammaged your O2 sensor (or wiring) and the ground fault is blowing ECU fueses. The car will crank, but not start. Replacing the O2 sensor with a known good one is a good remedy if this is indeed your problem.
One possibility of many.
Old Sep 16, 2006 | 02:00 PM
702RSevo's Avatar
ok where is the ecu fuse and where can i find another 1 if it is blown.
Old Sep 16, 2006 | 04:20 PM
702RSevo's Avatar
never mind found its my o2 sensor missed up and blowing my ecu fuse thanks for the help
Bman513
Aug 10, 2016 01:24 PM
LakerRaider
Jan 17, 2009 11:18 AM
94TurboGT
54
Mar 23, 2007 07:24 PM
Derek888
12
Oct 5, 2005 10:53 AM
zstryder
Apr 19, 2005 09:57 PM
