Evo 4G63 Engine Rotation Direction
Old Sep 19, 2006, 08:29 AM
DJpowerHaus's Avatar
Does an Evo 4G63 spin reverse of a DSM 4G63?
I always hear about it spinning backwards compared to an Eclipse engine, but I think that's silly. I really have no info to base my opinion off of, and that is why I ask. I'm sure someone could go start their engine, take a peek and tell me.
Old Sep 19, 2006, 09:03 AM
Blkhrt's Avatar
There is no way to know...
Old Sep 19, 2006, 09:14 AM
No way to know? How's that? Cant see the direction the pulleys or accessories are spinning or something?
Old Sep 19, 2006, 02:42 PM
Warpath's Avatar
No, It only rotates backwards in Austrailia. Like our USDM toilets do.
Old Sep 19, 2006, 03:40 PM
Ha, that's a good one. I remember that episode of the Simpsons like it was yesterday. When Bart gets the Boot.
Anybody have this info? Seems like pretty simple info for someone to gather that has one of these cars. Of course I mean Evo4 and up.
So what is it.. clockwise or counter-clockwise?
Old Sep 21, 2006, 07:05 AM
confusionisbad's Avatar
I am pretty sure its clockwise, just as the DSM 4g63 engines rotates. Its the same block, just rotated 180 degree's. Head is the same for the most part. CAS is tapped on the exhaust cam rather than intake, etc. When doing timing or touching the timing belt, you always want to rotate it clockwise or else you risk the possibility of throwing timing off by putting slack in the belt itself.
Old Sep 21, 2006, 12:29 PM
Cool. That might make for some interesting RWD swaps.
Is the bellhousing pattern the same on the Evo 4G63? That would be 12.25" between lower bellhousing bolts. Less likely it would be the "RWD" pattern with 13.25", but you never know.
Old Sep 21, 2006, 02:02 PM
Ive read a post eslewhere of a guy doing a 4g63 swap on a 2g FC rx-7. Should be interesting when it is done.
Old Sep 21, 2006, 08:22 PM
I'm using an RX7 transmission on my 4G64 swap
Old Sep 21, 2006, 09:35 PM
Ackerson's Avatar
It is clockwise
The engine is not rotated 180 degrees, the intake manifold is still on the firewall side, the exhaust manifold is still on the radiator side. The engine is "mirrored", the accesories and the transmission are on opposite sides.
When doing the timing belt you have to rotate the engine counterclockwise 1/4 turn in order to move the slack in the belt to the tensioner.
Old Apr 23, 2019, 06:43 AM
Eddiesp's Avatar
Would an evo engine swap right in and would it be worth it?
Originally Posted by Ackerson
It is clockwise
evo=best IMO
May 19, 2017 12:25 AM
MSEngineering
13
Oct 7, 2007 10:53 AM
loodav
Australian Forum
Jul 31, 2005 03:45 AM
noriceoz
Lancer Engine Tech
16
Nov 24, 2004 07:19 AM
nutnbutturbo4
16
Apr 20, 2004 07:48 PM
Quick Reply: Evo 4G63 Engine Rotation Direction
