how much can the stock head studs handle?
Old Sep 25, 2006 | 05:24 PM
  #31
AlwaysinBoost's Avatar
I have stretched ARP headstuds on other cars before. I have the stock head bolts in the EVO, I spike to 24psi daily and have 72k on the stock engine without a single issue to date.
Old Sep 25, 2006 | 05:39 PM
  #32
whitey4d's Avatar
Originally Posted by Gusl
If you are going to be removing the head, change the head gasket, head studs, bolts, retainers everything all at the same time if your pocket can handle it.
I have 43,000 miles on my car and it still runs like new. (at least to me) I have the Greddy 25G turbo kit & HKS 264s on my car now for the past 7-9 months running 27 pounds at peak boost with stock head bolts. No issue as of now. I am upgrading to the RNR 37R kit in the next few weeks and plan on running 28-30 pounds. I installed HKS 280s so I went ahead and installed the ARP bolts. I did them one at a time with no issues. You want to take one out and than install the new one. If you do them one at a time the head never shifts so it wont move around breaking the seal.
Like everything, nothing is a for sure thing. I was lucky and did not have any issues, be careful and take your time while doing it.
As a side note I have 2 friends that are running stock everything on there heads, 1 is at 30 pounds making 570HP the other is at 32 pounds at just under 600HP.
A head on a block can never shift even if theres no bolts in it. There are these things called dowel pins that do the aligning part. I agree that its ok and was told by David Buschur that 1x1 is fine and ok.
Old Sep 25, 2006 | 05:46 PM
  #33
silex's Avatar
Most probably won't admit to it as that's alot of money down the tube for something that can be prevented by replacing the oe studs.
Conclusion:
If you're doing your internals of any kind (ie. cam replacement), then just do the head studs among the other things recommended. If you're just upping the boost due to supporting mods (tbe, flash, mbc), then it's at the owner's discretion, but there have been nobody to my knowledge that has blown a head gasket under this cicumstance. If you go a step further and run race fuel or methanol injection, it's at even more owner's discretion (not enough people to justify).
If the car is daily driven, I would run 28psi at most in short bursts. If it's a daily/weekend, I wouldn't chance it at all and would do the studs. Full blown race car? We wouldn't be having this convo then.
Old Sep 25, 2006 | 06:03 PM
  #34
Ryu123's Avatar
For all the individuals that say "I installed the headstuds using the 1x1 method and have no issues", I have to ask if you've actually look up the backside of your block from underneath the car to see if you're leaking oil? I thought everything was fine with my install until this weekend when I went underneath to look around and realized that was not the case.
Old Sep 25, 2006 | 06:16 PM
  #35
cdupont03's Avatar
I did mine 1X1 and have no problems. I seem to tear my car apart atleast once a month and have not noticed any leaks from anywhere. I had almost zero experince working on cars when I did mine. The write up they mentioned is a good one and detailed. Just make sure you follow instructions and buy a troque wrench.
Old Sep 25, 2006 | 06:18 PM
  #36
whitey4d's Avatar
I bet its the valve cover.
Old Sep 25, 2006 | 06:20 PM
  #37
whitey4d's Avatar
I guess people dont beleive that a valve cover leak can go all down the block and hit the ground. Ive seen it alot actually.
Old Sep 25, 2006 | 06:30 PM
  #38
Ryu123's Avatar
That was the first thing I checked and its not the valve cover.
Old Sep 25, 2006 | 06:39 PM
  #39
whitey4d's Avatar
Hey its your car but i bet its not the HG causing ur leak. if u broke the seal of the HG then you would be blowing coolant out your overflow tank etc and would be more likely to have a coolant leak then oil. Have u checked the half moon seal in the head? Also reseal the corners of the gasket.
zedevo
12
Oct 26, 2008 08:14 PM
(GSX95)
Nov 29, 2007 11:58 PM
Thegame
Jun 28, 2007 12:19 PM
Blue Evo 8
17
Dec 22, 2006 07:49 PM
patan
May 25, 2004 03:43 PM
