Fuel cut
Old Sep 25, 2006 | 01:19 PM
k270kmh's Avatar
Fuel cut
Hi guys, I would like to know what is causing fuel cuts on my car.
Evo 7 with HF cat, cat back, removed the gommet inside the boost solenoid valve(increase the boost pressure), stock fuel pump, Ralliart ECU.
When I'm 1/2 throttle pressure it is fine 1,2...5th gears
When I'm at WOT the car gets fuel cut at 4th and 5th gear in high rpms (4500+)...
I would like to know if the fuel cut is happening due to stock fuel pump not being able to support enough fuel for 22 spike, 19 redline or an overboost condition or the ECU not supporting the increased air volume.
In the mean time I will put back the grommet.
Old Sep 25, 2006 | 01:39 PM
EVIL_EVO_VIII's Avatar
what is it spiking to?
Old Sep 25, 2006 | 03:57 PM
k270kmh's Avatar
Old Sep 25, 2006 | 04:10 PM
Speedlimit's Avatar
Admin Emeritus
It happens at 1700 Hz Karman value at 20°C and 1000 mbar atmospheric pressure approx. That is roughly 1.2 bars relative boost. You are either sucking too much air or your boost is set high for the relative temperature and pressure you're experiencing.
Speedlimit...
w0LF.e
Mar 30, 2016 07:52 PM
dac001
Jan 6, 2010 01:07 PM
got boost??
Oct 29, 2006 06:20 PM
AlwaysinBoost
42
Oct 30, 2005 07:16 PM
Chris@nolimitmotors
16
Nov 28, 2004 08:06 PM
