CLutch pedal....high engagement
Old Oct 7, 2006 | 05:09 PM
03SilvaEvo's Avatar
I have 25k miles now on a mostly stock evo 8. STill have the stock clutch and I feel the clutch engagement is a bit high. This calls for a pedal adjustment I assume.
Old Oct 7, 2006 | 07:07 PM
ACTman's Avatar
PM sent.
Old Oct 8, 2006 | 12:01 PM
hk2ronin's Avatar
can you send me that pm to? im completly stock though.
Old Jan 9, 2007 | 10:11 PM
Laxman's Avatar
Can you send that to me too? Much appreciated.
Old Jan 9, 2007 | 11:43 PM
vegasboy301's Avatar
can you post it? lol
Old Jan 9, 2007 | 11:47 PM
TogueMonster's Avatar
Send it to me twice, kthnx bye!
Old Jan 9, 2007 | 11:55 PM
omfg.
Old Jan 9, 2007 | 11:59 PM
clarkkent06's Avatar
umm....so what happened?
Old Jan 10, 2007 | 08:11 AM
ACTman's Avatar
For those inquiring minds
I still have the stock clutch on an 03 evo. I feel the engagement is too high. So that calls for a pedal adjustment right?
The right adjustment for an EVO is a bit on the high side for my liking when the clutch is in good shape. However a worn out clutch in addition to slipping, will also exhibit higher engagement/disengagement point than normal so if it has gotten higher, beware. To adjust it lower will not help anything other than your comfort in driving, but adjusting it too low will cause premature wear on the syncros especially if you like shifting as high rpms (like 7k). I hope that helps.
I haven't been experiencing slipping. Just wanna get the engagement to be just a tad bit lower than the high side and I don't wanna get it too low.
Simply try it a little lower, but be careful not to go too far and understand that if shifting at high rpms is affected, you need to adjust it higher.
Dragking2189
Aug 20, 2013 09:23 AM
texrex2002
Mar 6, 2007 01:54 PM
smokedmustang
51
Sep 20, 2006 05:30 PM
elhalisf
42
May 18, 2006 11:40 AM
prototypemike
Lancer Tranny/Drivetrain Tech
11
Mar 27, 2005 07:46 PM
