Crank Question
Old Dec 15, 2006 | 12:09 PM
Nash Mn's Avatar
My car is back on the road again running great with a 7 bolt DSM crank and 7 bolt DSM rods.
Old Dec 15, 2006 | 12:28 PM
CO_VR4's Avatar
Originally Posted by WOT
i beleive the evo crank is nitrided from the factory, while a regular 7 bolt dsm is not.
Allmost all 4g63 turbo motors used factory nitrided cranks. That why the FSM recommends against grinding them undersize.
Old Dec 16, 2006 | 02:08 AM
barneyb's Avatar
Originally Posted by colonelfox
The cranks are similar and interchangable, but not exactly the same. From what I can see the DSM crank will fit, but it needs to utilize a 2G DSM thrust bearing as the thrust bearing seat is different on the Evo crank. Dimensionally they're identical.
I'd have a hard time convincing myself to use the 2G thrust bearing considering it's reputation.
Old Dec 16, 2006 | 04:25 AM
colonelfox's Avatar
Thank you for reminding me. After looking at it again, it seems like the Evo thrust bearing type is what gets used. I know someone here has done this swap and can chime in for sure. Anyone?
Old Dec 16, 2006 | 06:09 AM
Nash Mn's Avatar
I used all EVO bearings in mine.
Old Dec 19, 2006 | 08:34 AM
scheides's Avatar
EvoM Moderator
a 2G 4G63 crank in an evo works, and it works well! The cranks are perfectly interchangeable, but evo bearings are a must. Nash's car is back on the road with a 2G crank and Crower rods designed for a 2G 4G63 7-bolt. Not only that, but the car is insanely quick on just pump gas! I think that all 387 whp (22psi on a dyno dynamics dyno) on straight pump gas will testify that this will be a huge cost saver for evo guys doing a rebuild. I picked up a 2G crank myself in preparation for this!
Old Dec 19, 2006 | 08:48 AM
Nash Mn's Avatar
And it gets to go back on the dyno tonight get some more part throtle tuning done and maybe some c16 tuning.
Old Dec 19, 2006 | 09:47 AM
scheides's Avatar
EvoM Moderator
What bearings were actually used?
Old Dec 19, 2006 | 10:12 AM
ecuflasher's Avatar
Has anyone used the Eagle forged 4340 forged steel crankshaft instead of the factory piece? Anyway, what's the part number of the factory forged steel crankshaft?
Old Dec 19, 2006 | 05:43 PM
Nash Mn's Avatar
97+ 4G63 bearings.
Old Dec 19, 2006 | 08:30 PM
dorsalfin's Avatar
Thats awesome to know it will work!
Old Dec 20, 2006 | 02:12 AM
Nash Mn's Avatar
It works awesome. Got it dynoed again tonight, 24psi pump gas, and it made 402hp/320tq on a AWD Dyno Dynamics dyno.
Eballution
Apr 1, 2016 01:15 AM
heyythurr
Nov 3, 2014 11:52 AM
real fast
Aug 11, 2014 09:13 PM
Darkn3s
Mar 11, 2014 03:45 PM
