clutch hits floor
Old Oct 24, 2006 | 07:49 PM
03evoyellow's Avatar
clutch hits floor
i was wondering if anyone has experienced this. was driveing car clutch was working fine the all of a sudden no pressure. it would pump up but not hold pressure. i went home and i added a half a pint of brake fluid to resovoir. The brakes worked fine no issues no leaks any where. just bleed clutch and its back to normal. Does anyone know what could have caused this? everything was bleed and checked when the sheptrans went in. Im stumpped.
Old Oct 25, 2006 | 07:04 AM
jqturbo's Avatar
I've had this happen in my Eclipse a few times! There might be the slightest leak where you can't see...or your clutch slave cylinder might be going bad. I had to replace mine in my GS-T...twice!
Old Oct 25, 2006 | 07:06 AM
EVIL_EVO_VIII's Avatar
May still have some air in the lines
Old Oct 25, 2006 | 07:24 AM
Benja's Avatar
Yerp....re-bleed the clutch system with new fluid and see how you go...
Old Oct 25, 2006 | 09:18 AM
19psi's Avatar
+2 on the air in your system.
Re-bleed the system thoroughly.
Old Oct 25, 2006 | 08:56 PM
thanks thats what i was hoping for
vmrevo9
15
Oct 15, 2011 11:13 AM
armysoldier1073
11
Sep 19, 2011 05:29 AM
Fifty
May 27, 2010 06:49 PM
nick_622
15
Apr 30, 2009 03:17 PM
shiftdsm E
Sep 12, 2007 10:37 PM
