EVO IX Cosworth Cams - The 1st Round of Results are Here!!!
Not sure if I can provide any usefull info. If I remember correctly, DB tested trottle bodies to give 5-10HP when the intake manifold was port matched to the bigger throttle body.
This might have a slight effect on before after numbers, but so would anything else like decat, LICP, intake..... I doubt that it has as much effect as the before and after tunes though! It is gonna be almost impossible to determine an exact number for HP gains with a given set of cams as people have different mods / tuners / gas / temperature.
IMHO, Works graphs show that there is SIGNIFICANT gains with cosworth cams.
Originally Posted by x838nwy
I think I have been misunderstood. The hp numbers in my post are totally imaginary, I am requesting for numbers without the throttleboby which as far as I understand it, the tests were with/without cams but on both occasions the larger throttlebody was used. The fact that I used HKS really didn't have any bearing on my point, it was just a brand that I know the rough price of.
I am wondering whether the larger throttlebody actually amplified the effectiveness of the cams. Or, in other words, would the stock throttlebody present a bottleneck when the Cosworth cams are used.
I am highly impressed with the results here and have a lot of time for Works and Cosworth. However, since it's a lot of money -~$1,500 for the whole lot - I'm interested whether or not it's worth getting the throttlebody.
FWIW, I don't own a IX although I am interested in its developments. My main interest here is regarding how Cosworth components perform and whether or not cams benefit to any significant degree from larger throttlebodies even on a stock turbo.
Originally Posted by OliSim
Here is the dyno graph and a Variance Graph as an added bonus.
Was your run-to-run variation THAT high?
These are very nice gains but they also are due to the high lift of the cams which gives even more power.. Im assuming these are more aggresive than the 280s..I wana see some results with other members here that have bolt ons and stock throthle body
Our strong recommendation for valve springs and retainers has to do with the potential contact between the OEM retainer and valve stem seal. See this thread for a thorough argument for both sides: https://www.evolutionm.net/forums/showthread.php?t=117752&page=1&pp=15 With the relatively high lift on the Cosworth cams, it's not a risk we're willing to take and considering what's at stake, the added cost is minimal. Even Cosworth's own documentation states, "These camshafts should be used with Cosworth valve springs for proper operation."
The WORKS Aperture Throttle Body is already matched to the inlet on the stock manifold. There's no need to port anything. (The WRP Aperture II is larger than the OEM inlet could be ported to match for more airflow.) As stated previously, both before and after runs were done with the Aperture on the car. In general, we see 8-12 HP gains with the Aperture, but most of the difference is in throttle response. Again, we were trying to provide a good comparison for the cams alone while at the same time getting results for the WORKS TR-340 package for the IX.
Jamie,
Is the trottle body of european/japanese/american IXs the same and would I need a custom tune if I just install the works TB on an otherwise custom tuned car with my mods + cosworth cams?
TIA, Can
TIA, Can
1. Upgraded springs and retainers (whether it's WORKS or Cosworth) are not required, but highly recommended.....
Oh, and thx for hitting a good candidate! Exhaust/intake/tuned --> perfect choice!
Originally Posted by UCB
cams on an otherwise bone stock motor are useless. You only need cams once the airflow through the head starts to outpace the stock cams. The gains on a car with intake/full turboback/etc will be more more than on just a stock car, and I dont see why anyone would install cams on a stock car either, when a TBE and tune is cheaper and doesnt involve cracking open the head
Regardless of peak numbers, the delta these cams provide is solid
TBE/intake/etc tuned vs TBE/intake/cams/etc tuned is what was performed, you cant really get any better comparison than that
In order to provide honest & valid numbers as to how much a single product makes, one must dyno a stock car and then dyno that same car on that same day with the new cams installed. The difference in whp and wtq is the real world data of how much the cams make. Seems pretty simple to me. I don't understand how you can justify your statements and these results by saying: "Well it would be useless to install cams, if you didn't do all of those other mods first." That's not what is in question here, What is in question is: How much do just these cams actually make. And these graphs prove nothing to that effect. They prove how much they make with a Works TR-340 package installed. 2 totally different results.
Yeah after reading a tad, these works plots do seem a bit fishy (seems as if the pulls were done on different days, the graphs dont quite line up correctly)
However for your enjoyment, GSC just posted plots, before and after on an untuned car, then tuned it (kinda)
Then you will see where im coming from. Ill stick by my statements however, cams on a stock car-huge waste of money, cams un-tuned-huge waste of money.
Spending $600+300-400 on cams on either a stock car or an untuned car is really silly. Like I said, you only start to NEED cams once the flow through the head starts to outpace the duration that the stock cams provivd, on a 100% stock car, cams wont be nearly as beneficial.
Before and after plots of un-tuned cams doesnt tell you anything either, in fact as you will see with the GSC cams, the car lost power in some areas due to the car running rich, I dont see why anyone would base any sort of decisions to buy or not to buy on such a comparison
Where cams really shine is when boost levels are elevated and the car is properly tuned, as that is where you will see the largest deltas. This usually happens with a full TBE/filter/raised boost/tune. From the modding stand point, cams are usually the next logical step, so to compare a TBE/filter/raised boost/tuned car vs the same car with cams is the best way to go (IMO).
Unfortunately GSCs car was not tuned at all before the cam install, so its hard to say if the delta in HP was due to them leaning out the AF or mostly due to the cams themselves
Originally Posted by boomn29
What do you recommend safely revving to with upgraded internals then? The dynochart cuts off at 7500rpms.
Just to reiterate, the test car was an EVO IX with 91 octane and the following mods for the "baseline" run:
WORKS Brain Flash P2
WORKS High-Flow Drop-in Filter
WORKS Aperture
WORKS Exhale 76mm Thermal Coated Downpipe
WORKS WRP Exhale High Flow Cat
WORKS Exhale 76mm Resonated Intermediate Pipe
WORKS Exhale Axle Back Muffler
Considering most modification paths follow a filter/intake, turbo-back and some sort of tune before cams, this was the perfect candidate.
The "after" run also included the addition of the Cosworth MIVEC cams and the WORKS V-springs/Ti-retainers with the Brain Flash software adjusted accordingly.
WORKS Aperture
Originally Posted by diablo2184
Was it a Mustang Dyno that you guys ran on? I just dont see how you guys had all these parts on the car and only made 313whp with cams.....I know on the Dynojets IXs make over 320 with just TBE, Intake, and a Flash (with boost turned up). Does your flash turn up the boost as well?
The WORKS Brain Flash P2 keeps the boost from tapering through software changes in conjunction with the WORKS Boost Hose assembly. We typically target ~20 PSI all the way to the rev limiter on pump gas, but can increase the target PSI as well as taper up, taper down or have it follow a sine wave.
We aren't concerned with the peak number. The number of interest is the difference before and after as that was the sole reason we did the "baseline" runs. It could have put down 100 before & 110 after or 500 before & 550 after. The results would have been the "same" as far as the gains from the cams are concerned.
Ok, so your baseline run was a car with your TR package, right? I guess making 31 whp and 29wtq is pretty good for just adding in cams (if i am getting this correctly). Whats the average whp and wtq for a stock IX on a Mustang dyno?
TACH_MOTOR_WORK
EvoX 'For Sale' Engine Internals and Drivetrain
36
Mar 9, 2014 02:47 PM
Jamie@WORKS
Oct 31, 2006 04:02 PM
