Helix Hollow 272 Cams Installed - No Problems At All
Old Nov 1, 2006 | 09:12 PM
Pd1's Avatar
Pd1
I decided to try out a set of the new Helix Hollow 272* camshafts and I've got nothing but good things to say about them. Unfortunately, I don't have much more than "butt dyno" data to show the gains. Boost dropped about 2psi overall after installing the cams as a result of increased airflow. I changed to these cams from the HKS 264/264 set, which provided a huge torque punch from 3500-4500rpm, but didn't have as much guts on the top side. The Helix cams provide a smooth ramp up through the RPMs and retain power up through redline.
These seem to respond to cam gear settings just like the HKS 272's do. I ended up with a -4/-1 setting which hits peak spool at about 3600rpm in 3rd gear starting from a 2k roll. This is a top end gear setting, of course. It also provides enough overlap for a reasonable idle. Conversely, a +1/-1 setting provided peak spool (21psi) by 3200rpm but didn't have the top end punch of the -4/-1 configuration and didn't idle quite as well. All of my testing was done via DSMLink with a MAP sensor being logged.
Bottom line is that nobody should be afraid to go with the Helix hollow 272 cams. They work just as well as the HKS variety, are hollow (just as Mitsu designed your stock cams), and are very reasonably priced at $400 a set from Gruppe-S.
If anyone has any questions about my experience with these cams, feel free to ask. I've been running them for about 3 weeks now with no issues whatsoever.
Attached Thumbnails Helix Hollow 272 Cams Installed - No Problems At All-dsc01056.jpg   Helix Hollow 272 Cams Installed - No Problems At All-dsc01057.jpg   Helix Hollow 272 Cams Installed - No Problems At All-dsc01058.jpg   Helix Hollow 272 Cams Installed - No Problems At All-dsc01059.jpg
Old Nov 1, 2006 | 10:59 PM
Jax419's Avatar
Good to hear, I actually bought a pair, but then sold it again because I decided to get a IX and sell my VIII!
Old Nov 2, 2006 | 12:13 PM
EvoTornado's Avatar
Good info here, Pd1! I've been pondering about Helix 272's. Thanks.
Old Nov 2, 2006 | 02:34 PM
Aby@MIL.SPEC's Avatar
nice review.
Were you able to see a maf reading difference between the cams & cam settings suggesting a power gain?
Old Nov 2, 2006 | 03:52 PM
Pd1's Avatar
Pd1
Thanks. Anyone in SoCal needing a cam install should call WOT. He's a highly competent and trustworthy guy who works for reasonable fees.
Airflow improved on the top end by about 1.5lb/min, which is roughly 15hp, with my current settings.
Originally Posted by WOT
nice review.
Old Nov 19, 2006 | 07:37 PM
Spec'd's Avatar
Very interesting ...
These Helix V2 seem to be the first hollow aftermarket cams available.
I'm surprised these aren't getting more attention.
Old Nov 19, 2006 | 07:40 PM
boscoyo's Avatar
Tomei and Jun cams are hollow.
Old Nov 19, 2006 | 07:44 PM
Spec'd's Avatar
Oops I didn't know that.
The Helix Cams still seem like an interesting product... I think.
Old Nov 19, 2006 | 07:59 PM
Rcebowl's Avatar
umm dont qoute me on this .. but i remember reading on this board... that was a Rumor and neither of those are hollowed as well
anyone have any say in this?
sorry to thread jack
great review btw... cams look great!
Old Nov 19, 2006 | 08:19 PM
EvoTio's Avatar
Thanks for the review. In fact I was just inquiring about Helix 272's on a SoCalEvo thread today. I've been reading alot about how well the +1/-1 cam gear settings do on the HKS 272's and would like to try it on some Helix's.
Old Nov 19, 2006 | 08:51 PM
boscoyo's Avatar
Rumors die hard, I guess. I was under the impression that they both use stock Mitsu cam blanks. I'll do some searching. Yes, nice write up.
Old Nov 19, 2006 | 09:48 PM
Pd1's Avatar
Pd1
Thanks. They're not blanks of any kind...they're billet. Mitsu uses cast.
Old Nov 19, 2006 | 11:22 PM
Spec'd's Avatar
According to Gruppe-S... they are not Mitsu OEM blanks.
Old Nov 20, 2006 | 05:08 AM
trinydex's Avatar
this is my understanding as well
Old Nov 20, 2006 | 09:07 AM
boscoyo's Avatar
After a late night of searching going back to early 2005, I believe it to be true, also. It was written that Jun and Tomei are not offering hollow cams at this time. Do you think that they offered them at one time or never offered them at all? Comp cams are hollow, right?
Back to Helix cam review.
Gruppe-S
18
Jul 20, 2007 05:41 PM
Gruppe-S
18
Oct 23, 2006 11:10 AM
Gruppe-S
14
Aug 22, 2006 09:25 PM
Gruppe-S
Gruppe-S Engineering - California
50
Aug 15, 2006 12:33 AM
Gruppe-S
15
Aug 10, 2006 07:36 PM
