Wideband sensor placement for IX
Old Nov 2, 2006 | 03:52 PM
spyderx's Avatar
As I understand the O2 bung is placed on the stock cat for the IX's. So, where do you place the second sensor for the wideband meter?
Any IX addressed this?
Just picked up a IX SE and planning to install the exhaust and wideband...
Old Nov 2, 2006 | 04:04 PM
EVOLVEU's Avatar
good question, I am looking into this too
Old Nov 2, 2006 | 06:30 PM
2 fas 4 u's Avatar
makes no sense to insall wideband with stock cat. need to remove cat get a straight pipe and weld bung on straight pipe.
Old Nov 2, 2006 | 07:50 PM
spyderx's Avatar
my point is that the IX has stock bung on the cat vs. the midpipe of the VIII. So, where would you find that second bung for aftermarket wideband sensor whether you're running cat or test pipe.
I don't want to make a trip to welding shop just to install wideband...
Old Nov 2, 2006 | 09:08 PM
mnbvcxz's Avatar
to get an accurate reading you would wan it before the cat. and since it's a turbocharged vehicle you want to to be about 28" from the turbo. too close would be too hot for the sensor
Old Nov 2, 2006 | 10:38 PM
EVO9MRNJ's Avatar
you need to have a shop weld you a bung into your exhaust for the wideband!
Old Nov 14, 2006 | 08:27 AM
Warrtalon's Avatar
Yeah, it doesn't matter where the 2nd o2 bung is - you need to weld a new one in the downpipe for the wideband.
2fas4u, have you gone to the track yet?
Old Nov 14, 2006 | 08:49 AM
dan628's Avatar
When you get a new exhaust it will have 2 bungs, one the on the test pipe and one right after the test pipe. I put the stock 2nd o2 sensor in the 2nd bung, and I will put the wideband in the bung on the test pipe.
Old Nov 14, 2006 | 09:08 AM
JDMevoBOOST's Avatar
yah but what about folks not running a testpipe
Old Nov 14, 2006 | 09:40 AM
thatguy's Avatar
Does your setup create accurate 02 readings?
Old Nov 14, 2006 | 09:43 AM
dan628's Avatar
I don't know yet, that's why I said "I will put the wideband..." meaning I have not done it yet, but I am sure the readings will be fine, why wouldn't they be accurate???
Old Nov 22, 2006 | 03:50 PM
BoOsTinGEVO190's Avatar
Planning to put the wideband sensor right into my test pipewould it read right?
Old Nov 22, 2006 | 06:07 PM
ant_turbo's Avatar
Here's where I have mine! In the stock downpipe...16' away from the turbo.. before the cat just had to have a o2 bung welded in....(ZEITRONIX)
Works fine.
Old Nov 22, 2006 | 07:31 PM
thatguy's Avatar
thanks for the pic
Old Nov 24, 2006 | 08:08 AM
evoNine's Avatar
unless you buy an o2 eliminator and use the bung thats with your exhaust for the wideband...
06 IX
buschur TBE catless w/bullet
intake
hallman mbc
255
ecuflash v9
Exsubie22
Jun 6, 2017 06:11 PM
alexc
Dec 31, 2016 11:06 AM
D1andonlyantman
Dec 22, 2016 07:55 AM
Jonas
Lancer Engine Management / Tuning Forums
12
Apr 15, 2009 04:17 PM
orikosan
11
Jun 21, 2004 11:05 PM
