New Stage1 clutch smokes out of garage
But only needed pedal adjustment to fix
Just installed Exedy Stage 1 clutch with resurfaced flywheel. Have 150 miles on it
Is it normal that I have to slip at 2000 rpm to get the car to move? any lower and the car will vibrate so I have to slip higher up and smoke it just to back up
It just grabs, vibrates, and scrapes instead of slipipping heating and then holding
Would removing the restrictor in the release cyl help?
EDITED TO ABOVE: Pedal adjustment fixed and I am glad (thanks to 992gnt)
i hav the same clutch with resurfaced flywhell too
it works perfectly fine for me, other than the expected noise wen letting off the gas while rolling along in gear
but i do get a heavy grinding sound followed by a nasty burning smell when tryin slowly creeping up steep hills, such as taking off at a stop light on an incline
however if yer gettin those problems on level ground, in normal accelerating conditions, u may wanna hav whoever installed it take another look
its a good clutch but installation may hav been faulty
Did you adjust the clutch pedal? I'd be willing to bet that's the number one cause of premature death of an aftermarket clutch. It should engage similarly to the stock clutch. Hopefully you haven't slipped it too much and ruined it already...
No, the thing engages way before I lift the clutch, like by 1/2 up, it's been long engaged.
There is absolutely nothing wrong with install, I spent 3 weeks doing it myself, ever bolt was torqued 4 -5 times until target. I even completely overhauled the release fork
I'm guessing the people who resurfaced my flywheel may have dropped it or the flywheel was damaged befor I got it. or maybe pressure plate was dropped. I don't know, I went through the meticulous trouble of installing right for this
Maybe it needs a little abuse nows a good time becuse I pissed off
Did you adjust the clutch pedal?[/QUOTE] I just adjusted it two turns down on pushrod...
IT WORKS!!!
Engages like stock, 992gnt I owe you,
Thanks
180 miles, I hope not, I doubt it because the only smell was during take off and it wouldnt slip on accel
IT WORKS!!!
Thanks
Originally Posted by 992gnt
?Hopefully you haven't slipped it too much and ruined it already...
Originally Posted by mchuang
Wow 3 weeks lol sounded like fun did you get any grease or anything on the contact surfaces.
KY jelly slipped that baby in there
Took that long because of 2-3 hrs on weekdays was all I had,
Problem fixed thanks to 992gnt, my stupid *** was too stuborn to adjust the pedal thinking "how can that be it"
I'm putting "thanks 992gnt" in my sig
jamaicaboost
Sep 28, 2016 11:55 PM
alfredoaal
16
Feb 28, 2016 10:58 AM
deegaw11
13
Feb 27, 2007 12:20 PM
