Head Cam Caps swap
Old Nov 14, 2006 | 08:30 PM
mikiblueeyes's Avatar
Head Cam Caps swap
Hey guys need advise.
I just got a used head in replacement of my Bushur racing one that has hairline crack. Now the Cam caps would not fit the same way they did for the old head. Are they swappable or each head has to have its own cam caps?
What is the way to make it work? ??
Please let me know.
Alex
Old Nov 14, 2006 | 08:50 PM
jmartinez1170's Avatar
Order brand new ones and see if they fit.
Old Nov 14, 2006 | 09:21 PM
Anyone else?
Old Nov 14, 2006 | 09:39 PM
CharlieGsanD's Avatar
cam caps are not interchangable either in position on the same head or from diffrent heads,
during assembly of the head, the cam caps are bolted to the head & then line bored to ensure a precise fit
Old Nov 14, 2006 | 10:18 PM
kjewer1's Avatar
Your only option if you don't have the right caps is to have a machine shop cut the caps down and re-bore it.
Old Nov 15, 2006 | 07:53 AM
Thanks for the info Kevin
Old Nov 15, 2006 | 09:00 AM
So when i changed cam caps from one head to another it fit with no issuses.
Old Nov 15, 2006 | 09:37 AM
just because "it fits" does not mean it is correct.
i know what im talking about here. there is a reason they are numbered & have arrows on them.
Old Nov 15, 2006 | 09:47 AM
hotrod2448's Avatar
Maybe it's things like this why you have had so many issues in the past.
You wouldn't swap main bearing caps from one block to another would you? Or Connecting rod caps?
None of them are made to be interchangeable.
Old Nov 15, 2006 | 12:56 PM
kjewer1's Avatar
I've seen heads that had the wrong caps that "seemed" fine, you could rotate the cams by hand, etc. But after very short mileage pulled the caps and two of them were smeared to ****. The aluminum is soft and gets out of the way, and it may continue to run fine for a while, but it's no way to run a motor.
EvokidIX
Jan 14, 2015 10:36 AM
LaFuriaRoja01
Jul 9, 2014 09:44 AM
hylomar
Feb 1, 2012 07:47 AM
slvrevo
Aug 14, 2005 02:48 PM
darkhorse
25
Aug 10, 2004 10:41 PM
