Turbo problem :(
Old Feb 5, 2007 | 08:54 AM
#2 SM's Avatar
Bump.
I have a similar issue...
Did you isolate the problem?
Old Feb 7, 2007 | 12:02 PM
diablors's Avatar
yes. it was my lower intercooler pipe where the connection meets the turbo inlet. check all of your intercooler pipe connections. On the factory intercooler piping there is alot of connecting points that can come loose. I hope this helps you
Old Feb 7, 2007 | 01:39 PM
#2 SM's Avatar
Do you mean the black "lower discharge" pipe that bolts into the compressor housing; or the actual lower intercooler pipe's connection to that black lower discharge pipe?
Unfortunately, I have recently replaced both and the car is boosting a lot better but the noise persists...
I will do another leak down test Friday to see if I have missed anything significant, otherwise I will do my best to ignore it.
Thanks for the response diablors.
Seth_Horton92
Feb 9, 2017 07:13 AM
KingTal0n
Nov 27, 2016 05:23 PM
zztt
Apr 23, 2014 06:31 AM
lethalevo
AEM EMS
Nov 30, 2010 02:53 AM
talon2evo
Mar 2, 2006 08:45 PM
