FPEvoGreen First Impressions
Old Nov 20, 2006 | 09:00 AM
Pd1's Avatar
Pd1
Originally Posted by nj1266
Bryan,
Saying that it is so does not make it so. What the OP is saying does not match the data posted. Here is the dataloglag gif. You can see that max torque, load, and minimum timing happen at almost the same rpm, ie, 5200 rpm. That is laggy in my book.
Look at 14.2 on the X-axis, and 200 on the Y-axis. That's where I hit 21psi at ~3800rpm. That's what the boost controller is set to reach (at least, that's what it was set to reach using the IX turbo on the same upgraded actuator). From that initial boost shelf, it creeps up about 2psi -- offering greater torque/load which peaks at about 5200rpm and then tapers back down to the original 21psi setting. This is precisely what I said in my original post, and I don't believe 21psi at 3800rpm equates to a "laggy turbo." I'm tempted to try a +1/-1 cam gear setting and see how much earlier boost comes on.
I haven't driven the car enough to know if the creep is just the EBC "learning" the curve of the new turbo, or if it's the HP actuator, or if it's just how this turbo works. If there's no correcting it, I'm actually fine with that since the extra boost actually comes on at the perfect time (just after torque peak--where knock is most likely), and tapers before things get out-of-hand at redline.
Old Nov 20, 2006 | 10:27 AM
David Buschur's Avatar
Since you spent time in my thread I figured I'd come into this one and make one post.
I can count atleast 7 items on your car that are hurting the performance of it and could be improved. Using this car as a test bed to show what this turbo is capable of is silly but the more EVO's I see come through here with a mix match of messed up combinations and parts choices on I guess in reality it is more typical than it should be.
Just remember, don't hold the turbo accountable for the power this car puts out if and when it finally hits the dyno.
Good luck and I hope you are happy with how the car runs. You'd make more power and have a better car if the combo was put together better, IMHO.
Old Nov 20, 2006 | 10:37 AM
Pd1's Avatar
Pd1
I'm all ears, David. What are the 7+ items?
Old Nov 20, 2006 | 10:44 AM
TTP Engineering's Avatar
More interested to see if it will hold the 30+psi at 8000rpms cammed like Dave stated in the other thread.
Old Nov 20, 2006 | 10:50 AM
justchil's Avatar
This data is pretty much useless without a tune I checked out your logs.. timing is all over the place.. 2* at 5200 (or around there) with a peak of 12*.. I would assume this is 91oct gas (may have been stated already).
#1 of 7 Magnecor Wires
Old Nov 20, 2006 | 10:54 AM
MrBubbler's Avatar
Resonated Test Pipe, Magnecor wires,
Old Nov 20, 2006 | 10:55 AM
thebluesky's Avatar
Feigning a guess, he doesn't like your injectors (they are a little small), your intake setup (which seems mixmatched to me), your exhaust setup (probably because they're not his),
your down pipe and 02 housing setup (same reason), your bov (which I would probably upgrade but is an alright bov), and the magnacores (which really don't sway me one way or the other).
Old Nov 20, 2006 | 11:17 AM
Spec'd's Avatar
Don't forget the original intentions of this thread.
From the first page ...
Originally Posted by Pd1
Let me start by saying that these are preliminary impressions and not intended to be the "final word" on the FPGreen turbo. I installed the turbo last night and have only had part of today to play with the new toy (tuning is not yet perfect). Let me also add that I don't have before/after dyno graphs. It's just not worth $400 ($175x2+tax) to get the dyno data. If you'd like to see a dyno sheet of my car in its current state with the new turbo, I'll be happy to accept a PayPal transfer from 9 people in the amount of $20 each and go to a nearby dyno within the next few days.
Old Nov 20, 2006 | 11:18 AM
Ev0ikon's Avatar
But I bought my Magnecor plug wires from my Evo8 from BuschurRacing!
:hmmm:
Last edited by Ev0ikon; Nov 20, 2006 at 11:21 AM. Reason: His mod list looks fine to me!
Old Nov 20, 2006 | 11:29 AM
RoadSpike's Avatar
:hmmm:
I see a couple people pick on
APS CAI
HKS RS Intake Pipe
Old Nov 20, 2006 | 11:33 AM
Fireball's Avatar
Agreed on the wires, but what's wrong with a resonated test pipe?
Old Nov 20, 2006 | 11:38 AM
KOEvo's Avatar
Yeah, what's wrong with a resonated test pipe?
Old Nov 20, 2006 | 11:41 AM
thebluesky's Avatar
Originally Posted by kimletrim
Umm....did everyone forget David's rant on other companies' O2 housings where he provided "objective" dating on how the O2 housing he sold was the best?
Pd1, you've provided good information. I must say you are brave to try out the new turbo. And as he said, this is only preliminary information. There is still much tuning to be done.
I must agree. Pd1 keep us posted on the progress with the tuning.
Old Nov 20, 2006 | 11:47 AM
Ev0ikon's Avatar
APS CAI
HKS RS Intake Pipe
That is just silly. Those parts don't affect the power output that much when properly tuned.
And a 3" resonator pipe doesn't cut much power either, yet in turn makes the car a lot more quite and acceptable in certain neigborhood.
Old Nov 20, 2006 | 11:54 AM
APS CAI
HKS RS Intake Pipe
This does not sound like a bad combo.
A bad combo would include a true HKS mushroom filter which this does not.
