How to ELIMINATE the 35R Fart Can
Alright I have a question. If we eliminate the twin-scroll setup and go with the 35r it will be a raspier noise correct? So would the noise be still there or toned down a little bit if someone were to use Full-Race Motorsports twin-scroll set-up?
Good question. I assume the tubular manifold does this. Many bigger turbo evos have this sound. I was also told it was due to thinner exhaust materials used over the stock cast manifold.
mufflers gonna give you the tone what you need is a resonator take it from me i came from high rev honda motors and i no what **** sounds like it will quiet your exhaust down a bit but kills the raspy just get a longer one from the start and be done ive switch more exhaust on my honda then most people have had cars in there life time amj exhaust shop was on speed dial
i have the same problem......... after my 35r build i ran straight 3" thru the buschur bullit muffler and sounded like ****...so i put a megan resonated test pipe in and went with a tusudo catback and i helped alot...still has a little fart sound when cold.....so ima try a mid pipe resonator
