Main bearings and rod bearing gone... :(
Old Nov 29, 2006 | 07:56 AM
  #31
Scawt's Avatar
Originally Posted by ifarted2
Well after lots and lots and lots of $ $ $
My mains and rod bearings are destroyed also the side of the BC pro rods were grinding into the crank B&M machine did the machine work and didn't check clearance on the crank and rods and mains
Sorry to hear about your luck, but didn't the machine shop give you piece of paper with your main/rod clearances on it? That's the first thing that I looked at when I picked up my 2.4 short block (rotating assembly) from the machine shop.
Old Nov 29, 2006 | 10:00 AM
  #32
HPF Kyle's Avatar
I usually write down ALL my clearances, ALL my turning torque figures at each point of assembly...and I track my oil pressure at what rpm at what engine temp. I take two points of reference. This way I when oil pressure drops 5-10 psi...i know.
If you're spending that much money on a car you might want to double check everything and have a mark to start from. If the bearing clearance was off from the start it would've shown in the oil pressure. Compare notes to another build with similar clearances, oil pump, etc.... may not be precise...but ballpark usually helps figuring out when/if there is a problem.
<-- extremely **** about his engine.
Old Nov 29, 2006 | 11:07 AM
  #33
CO_VR4's Avatar
It's interesting to me that many of the well known DSM/Evo engine builders do NOT provide a build sheet with a motor. While I understand that engine building is sometimes thought to be a big secret, it's one that can be shared with customers that are paying several thousand dollars for a product. I personally will not have a machine shop build a motor without providing a build sheet that shows clearances, torques, weights, etc. They come in very handy if you ever need to replace a part, and also serve as a "check and balance" to make sure that the assembly work was checked and double checked. If it's built as it should be, the engine builder has to have done each of these checks anyway. It's not much work to write it down as you go...
Old Nov 29, 2006 | 12:01 PM
  #34
Erik@MIL.SPEC's Avatar
Did you pay by credit card? I would dispute the charges for however much it costs to fix/remedy the problem.
Old Nov 29, 2006 | 02:40 PM
  #35
HPF Kyle's Avatar
Best spec sheet I ever saw.... Using factory subaru components... bearing clearance #1 .0030 #2 .0030 #3 .0030 #4 .0030
I was like riiiight you check'd it lol. I did the same build the week before with a new EJ257 case halves, new sti crank, Pauter rods, and CP pistons.... I KNOW it wasn't 3.0 thou on everybearing. 3.3-2.7 tho on the bearings. amazing to say the least.
Old Nov 29, 2006 | 03:45 PM
  #36
Paul Nelson's Avatar
Fix my fuel system Eric!!!
Its bad when i put gas in and it comes out the bottom of the car!!!
Old Nov 29, 2006 | 10:00 PM
  #37
HPF Kyle's Avatar
thats what makes it good paul.... its the overfill protection. lol
Old Nov 29, 2006 | 10:17 PM
  #38
Frenchy4g63's Avatar
Jeez.. sorry to hear about your bad luck, I would be pissed for sure. Have you heard if they're going to do anything to make this up to you? I would expect more then 1500 miles out of a motor I just spent thousands to build..
I'm sure you'll be happy with the new setup, and good luck with everything.
hutch959
11
Dec 28, 2015 05:23 PM
poonpower
Nov 6, 2015 09:06 AM
Dannievo
16
Apr 26, 2015 08:54 PM
SBR INC
Nov 12, 2009 06:18 AM
BoostedEvo21
11
Jun 10, 2007 07:44 PM
