Main bearings and rod bearing gone... :(
Old Nov 27, 2006 | 05:26 PM
Paul Nelson's Avatar
Well after lots and lots and lots of $ $ $
My mains and rod bearings are destroyed also the side of the BC pro rods were grinding into the crank B&M machine did the machine work and didn't check clearance on the crank and rods and mains...looks like they just cut the bearings to get it to fit the crank and see if the crank would turn. So ive got Lucas at English Racing takeing the motor out and sending it to his machine guy. I know that Lucas mainly works on 4g63 and has a awesome reputation
But the money and time ive put into getting this done right just got pissed down the drain. Well another 4 weeks and ill be back up and running and $4000 later
I dont know if i need to hit the bottle tonight or just go to bed. Depressing....
Old Nov 27, 2006 | 05:30 PM
scottatyamaha's Avatar
man i am sorry to hear that...were you the guy that had the thread the other day about your lifters honing out the rocker arm caps and filling the lifters with up with metal?
Old Nov 27, 2006 | 05:32 PM
Jim_Patterson's Avatar
******* sorry to hear man. What did B&M say about it? Good choice on EnglishRacing!!
Yup all the stuff from the bearings was going into the lifters... only 1500 miles on the motor. Ive done my best and havent gone cheap on one thing. but o well i should have did more research on builders and machine shops.
My tapping noise didnt happen till after the first dyno pull or real load on the motor.
Old Nov 27, 2006 | 05:34 PM
i had a feeling that something bad was happening. Good luck with your rebuild.
Yeah i spent all day with Lucas and was very impressed with him and his crew.
His customer service was good
I still havent told the wife yet the news any ideas guys how to break it to her? ive already got $25K into the car lol
Old Nov 27, 2006 | 05:36 PM
Man if ya only knew how much time i had getting parts toghther and working with mechanics and vendors....
Old Nov 27, 2006 | 05:48 PM
Tell her you need to sell her ring to fix your car.....lol
Old Nov 27, 2006 | 05:50 PM
well the evo was her car till i put a roll bar in it then i had to get her a bmw so now she happy. But i know im a dead man after i tell her
Old Nov 27, 2006 | 06:28 PM
dubbleugly01's Avatar
get the sex out of the way before you tell her.... it might be awhile after that
Old Nov 27, 2006 | 07:22 PM
ONRAILS's Avatar
dude that sucks bro, i know the feeling i'm $5,500 dollars into a build. Over a oil leak caused by mitsubishi.
Old Nov 27, 2006 | 07:33 PM
Lucas English's Avatar
Well we don't want to point fingers yet untell we get everything totaly apart and check things out. Which should be done buy Tursday.
I know side play on the rods is to tight and that is why the thrust side of the rod is chewed up.
I think the stock lifters took a crap do to metal from the bearings geting into the lifters.
Old Nov 28, 2006 | 05:32 AM
Jasil's Avatar
Good luck!
Old Nov 28, 2006 | 07:03 AM
CO_VR4's Avatar
I'm really sorry to hear of your misfortune. Lucas is a great choice for straightening out your situtation. I'm wondering how your clearances were off with brand new rotating parts from the same supplier. Guess that will be a topic of discussion somewhere soon.
Old Nov 28, 2006 | 02:13 PM
So im going back to a 2.0 but sticking with bc pro rods and cp pistons. Im just going to drag the car most of the time so it will work out good. The BC crank is 102mm which is a huge stroke and limits my revs by alot.
Anyone else running the bc 102mm crank? I would love to know what there input is and there luck with it has been
